Old Jul 31, 2005, 08:47 PM
Joined Mar 2005
Uzi XXL biplane- help! what motor?
Im ordering a Uzi XXL and need help on motor selection from one of you guru's The link to the plane is http://www.hobby-lobby.com/uzixxl.htm. I have a couple hacker 20-20l's and a HiMaxx HC2816-0890. I want close to 2 to 1. Will these motors come close? Or maybe get a bigger axi or one of the hacker A30's? Ill be using TP 2100's gen2's. Any help appreciated......
strat919 is offline Find More Posts by strat919
Old Aug 04, 2005, 06:36 PM
Joined Apr 2005
You'll need a 200 watt motor for the XXL. The POT200 (Potensky) motor is recommended by Hobby-Lobby. You could also go with the Cem200 (Python).
I like the Potensky motor better because it draws fewer amps. Meaning you could use an 18 amp esc vice a 25-35 amp with the python. Your plane will have an all up weight of about 25-28oz.
My Uzi XXL flew well with the Python, but my battery was a piece of crap. I just got my Potensky in the mail and I'm going to try it in the Uzi tomorrow with a TP battery pack. I could let you know how it went if you like. I'm not a Guru so I can't give any advice on the Hackers. I can only talk about what I use.
However, I think an Axi 2808 would fly the plane just as well. BTW, the Python hovered the plane at 1/2 throttle. And that was with the cheap Magnum battery from NeSail.
Steve
Doppelganger is offline Find More Posts by Doppelganger
Old Aug 06, 2005, 01:14 AM
Joined Mar 2005
Steve..... would love a report
Old Aug 06, 2005, 05:48 PM
I like them a bit tail heavy
tdab's Avatar
Carolina's
Joined May 2004
I fly mine on a an Axi 2814/12 with Jeti 30A ESC and it has plenty of power. I use Tanic 3s 2200's. AUW is 26.5 oz.
Great plane.
-Tom
tdab is offline Find More Posts by tdab
Last edited by tdab; Aug 06, 2005 at 05:50 PM. Reason: Edit...mistake AUW is 26.5oz
Old Aug 07, 2005, 12:27 AM
Joined Apr 2005
I'm sorry strat, I decided to stay with the Python motor. I have a Scorpio Spitfire laying around. I think I'm going to drop the Potensky motor in it. I'd suggest the Potensky because it's cheaper and draws less amps. Before I stripped the shaft on the Potensky, I had a chance to static test the motor on the plane. It seemed to have plenty of power.
If money is no object, go with the Python or Axi. You will never go wrong with an Axi.The great thing about buying a motor from Hobby-Lobby, is if you kill the motor, they will replace it at half price. I killed an Axi, and my Potensky in the same weekend. I sent them back to Hobby-Lobby and they called for billing info. I recvd the motors in a week. Not too shabby.
Old Aug 27, 2005, 11:10 AM
Joined May 2004
Hacker Outrunner
I just put the Hacker A30-M in my UZI XXL yesterday along with the Hacker X-30 speed controller. Plane weighs in at about 26oz. I'm using Kokam 3 cell 2000mah 15c lipos. At full throttle with an 11 x 4.7 it pulled about 25 amps coming out to about 143 Watts. Test flight resulted in phenominal performance! I wish I could 3D better (I'm working on it) but it would go vertical at just a tad more than half throttle. I flew it pretty hard for a little over 15 minutes and the motor was only warm. The battery pack was a little warmer than I'd like but still acceptable. I may try a 10 x 4.7 and see how that works.
One thing I like about using the Hacker motor and speed controller is that you can program many settings on the speed controller: Brake, timing, low-voltage cutoff, and even reverse spin to name a few. I'm very happy with this setup and I'd readily reccomend it.
Awtoo is offline Find More Posts by Awtoo
Old Nov 30, 2008, 04:45 PM
major3d's Avatar
United States, TX, Fort Worth
Joined Nov 2008
tdab how does it balance
Great plane.
-Tom
How did it balance? Did you have to add weight to the tail with that motor?
I want to use a lighter motor but, not if I have to add weight to the nose.
major3d is offline Find More Posts by major3d
Old Nov 30, 2008, 10:12 PM
D/FW
Joined Aug 2004
At that weight a Park 480 would power it nicely.
JoeDirtRC is offline Find More Posts by JoeDirtRC
Old Dec 01, 2008, 03:01 AM
stanordave's Avatar
Joined Jan 2006
I use a Turnigy 35-36 and it seems just the right size.
stanordave is offline Find More Posts by stanordave
Discussion need help what motor would work good? epoweredrc Flying Wings 14 Jul 13, 2007 11:11 AM
Video UZI XXL Biplane gquiring Electric Plane Talk 0 Jun 11, 2007 09:30 PM
Discussion Help - what motor set up for A Sky Sergio ? jrturbo Electric Sailplanes 28 Mar 19, 2007 01:42 PM
Wanted wanted uzi xxl biplane jeff webster Aircraft - Electric - Airplanes (FS/W) 1 Nov 29, 2005 01:17 PM
Dynamic 400 - Help What Motor SPEED-E-FLYER High Performance 12 May 22, 2004 12:11 AM
