Old Oct 26, 2014, 09:51 AM
Manudepron's Avatar
Belgium, Walloon Region, Namur
Joined Apr 2010
Question
ESC timing for a Turnigy 1230 inrunner 4500 kv
I built a profile prop in a slot Mig 15 with a Turnigy 1230 4500 kv.
I run on 2 S a 3 x 3 Gws prop and a 6A esc.
What timing is the best? Currently motor gets warm and I am on medium....
I don' want to burn this tiny motor
I am posting here because you often use this kind of inrunner...
Manudepron is offline Find More Posts by Manudepron
Old Oct 28, 2014, 03:01 PM
United States, AR, Jacksonville
Joined Jul 2004
Typically ESC manufacturers recommend low timing for low pole count motors, which inrunners would fall under (2 to 4 poles normally).
Whiskey Whiskey is offline Find More Posts by Whiskey Whiskey
Old Oct 28, 2014, 06:41 PM
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
GWS 3X3 might be a bit too much load, I use 3X2 with my Feigao 1230 of similar Kv with the same ESC . Here are some data;
http://www.bphobbies.com/view.asp?id=A0320074
As shown here the current increase a lot even on a 3X2 with higher 5300 Kv version:
http://www.bphobbies.com/view.asp?id=A0320082
coriolan is offline Find More Posts by coriolan
Old Oct 29, 2014, 01:59 AM
Manudepron's Avatar
Joined Apr 2010
Thank you both of you!
Old Oct 31, 2014, 01:00 PM
Manudepron's Avatar
Joined Apr 2010
Following your avices, I did a test yesterday on the bench and with an electronic balance to mesure trust.
With the 3 x 2, same battery: lower consumption but higher trust! Around 20 grs more !
1 week to wait until our next indoor venue....
Old Nov 01, 2014, 10:09 AM
Joined Jul 2004
Isn't it beautiful when that happens?
Old Nov 04, 2014, 01:47 AM
Manudepron's Avatar
Joined Apr 2010
I made tests again and I get 88 grs trust & 3.7 A consumption on low timing esc!
I am happy !
http://www.rcgroups.com/forums/member.php?u=310184
For Sale ALL NIB! 4500 Kv JetScreamer- Jeti SPIN 22 ESC and Jeti SPIN BOX Steve_A_Reno Aircraft - Electric - Jets (FS/W) 2 Nov 15, 2008 03:42 PM
Sold Jet Screamer 4500 KV with orig adapter for 56mm XF-Fan pre-installed bolarobric Aircraft - Electric - Power Systems (FS/W) 1 Mar 04, 2008 05:50 PM
Discussion Jetscreamer 4500 KV - problems !! Eole Electric Ducted Fan Jet Talk 16 Dec 01, 2007 11:05 PM
Discussion Wind/Magnet for Kv 4500 on 22.7mm GBL Single MGeo Electric Motor Design and Construction 7 Nov 05, 2007 11:17 AM
Sold For sale Ducted Fan with 4500 kv motor djdaveq Aircraft - Electric - Power Systems (FS/W) 3 Feb 02, 2007 06:21 PM
