Old Sep 18, 2013, 06:11 PM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Making the tape stick up that far might well have caused the trip to act more like a spoiler. If so then the effect on the controls you got is understandable. Try it again using some slit down masking or electrical tape laid on two to three layers thick by 1/8 inch wide. And you're looking for this turbulator to be located at around 1/5 the way back from the leading edge.
It's with issues such as this and trying things that I've found we learn the most. When things go perfectly first time and every time it's just too easy....
BMatthews is offline Find More Posts by BMatthews
Old Sep 18, 2013, 11:09 PM
iron eagle's Avatar
United States, MA, Middleboro
Joined Jul 2007
Sounds like you are right path. The fun in the hobby is you can experiment to get an idea of what can work for you.
The winglets should stay in a high aspect configuration that you have, just keep the root cord under 60 percent of the tip cord, and move them back so the trailing edge of them at least meets the trailing edge of the control surfaces.
iron eagle is offline Find More Posts by iron eagle
Latest blog entry: The third time is a charm!
Old Sep 20, 2013, 05:24 PM
United States, CA, Napa
Joined Apr 2013
So I slapped some bigger (less sexy) winglets on and gave it a go today. Unfortunately it was so damn windy I could barely keep it pointed where I wanted it to go. Down wind turns were exciting to say the least. Winds were coming out of the W directly, and the hill where I fly at lunch is not well suited for the westerlies (a barbed wire fence is my LZ ). I will have to try again next week.
A short video for your viewing pleasure...
1m RC Flying Wing Slope Soaring -Test Flight #2 + High Winds (0 min 57 sec)
daveoxide is offline Find More Posts by daveoxide
Old Sep 20, 2013, 09:10 PM
iron eagle's Avatar
Joined Jul 2007
Looks like it flew pretty good given the conditions.
Old Dec 09, 2013, 10:19 AM
EdSoars's Avatar
Salida, Colorado
Joined Sep 2002
Dave; your wing looks a little over-controlled in pitch. Is your elevator throw less than half of the aileron number? It could be as little as 20%, depending on CG. If you reduce throw, you'll need to be sure there is no slop in the linkage and hinges.
Your original tiplets had a lot of area below the wing, which might contribute to tip stall. Your new ones look like they have little or no area below the wing, but it's hard to see. Unless you intend to side-launch or discus-launch the wing, there isn't any need to balance the upper and lower areas.
ed
EdSoars is offline Find More Posts by EdSoars
Discussion Flying Wing Glider Flight Characteristics, Help Needed! daveoxide Sailplane Talk 7 Sep 18, 2013 04:59 PM
Discussion Flying wing for UAV/FPV help needed Paul_BB Nurflügel 17 Aug 24, 2013 08:04 AM
Discussion Wing area, aspect ratio, wingloading, and flight characteristics wingloada Sailplane Talk 16 May 10, 2013 02:18 PM
Help! Need help with polyhedral EPP glider wing assembly Alard Slope 8 Jan 15, 2013 04:08 PM
Discussion How are flight characteristics affected by different flying wing layouts? potshot Flying Wings 35 May 25, 2012 12:21 PM
