Old Jul 17, 2013, 10:36 PM
Joined Jun 2012
Help!
Random Nose Dives!?
Hey guys, I'm relatively new to RC and I've had quit a few experiences with planes crashing. However, I've never had a problem like this one. My friend and I build him a FT Flyer (Blue Dart). Looks great and construction seems to be very sound.(will post pics if needed.)
However we popped the electronics in the swappable fuselage and tried to maiden it. It would fly true for several seconds and then all of a sudden it would plunge into a violent nosedive. It is properly trimmed and flies level, but has a tendencies to dive randomly without user input. Checked everything and I can't detect the issue.
I figure it could 1 of 2 things.
1) Perhaps the radio is glitching from interference causing the servo to twitch? It is DSM2 only
2) The elevator servo is broken and moves unpredictably.
However I have not seen any of these issue in preflight and it has no other bad tendencies. I will further dissect this issue with field testing, but it looks like it may be a very hard mystery to uncover. Hopefully this is a basic beginner issue that you can set me straight on. Thanks in advance for your superior knowledge
Plane Specs.
1x Park300 1600kv motor
1x 18A Plush Speed Controller
2x HXT900 9g servos
1x Turnigy 500mAh 3s Lipo
1x Orange 6ch Rx w/o failsafe
1x T-SIX 6ch Orange Transmitter(DSM2)
ttrando is offline Find More Posts by ttrando
Old Jul 18, 2013, 12:56 PM
3D? I only got two thumbs!
United States, MA
Joined Jul 2012
Perhaps those are actually stalls?
AeroKen is offline Find More Posts by AeroKen
Old Jul 18, 2013, 02:44 PM
Joined Jun 2012
From flying my Flyer, I know how extremely docile this plane tends to be even at stall speed. Unless there is something very aerodynamically wrong with the air frame(which seems impossible, the thing looks great), the stall would not be nearly this violent. Also this occurs well above stall speed. Thanks though. Keeps the ideas coming!
Old Jul 21, 2013, 08:05 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Have you tried a radio range check ? (Try a genuine walk away with the servos working, not pressing the 'range check button', assume the Tx has one).
Rx antenna away from any metal, wires, carbon, and straight not bent ?
Tx antenna angled over to one side, (shouldn't point straight at the model).
If a servo has a problem, replace it. They are cheap enough, and it's not really worth risking ruining the plane, motor, prop etc.
eflightray is online now Find More Posts by eflightray
Old Jul 25, 2013, 10:07 PM
N00b Sloper Addict
Parkflyer81's Avatar
Australia, TAS, Brighton
Joined Dec 2005
Ive had the same issue with DSM2 products. I've changed out to another type of radio module and RX units, never had a problem since.
Parkflyer81 is offline Find More Posts by Parkflyer81
Old Aug 04, 2013, 10:05 AM
Wilson, NC
Joined Aug 2009
Hi ttrando
You state that the elevator servo is broken and moves unpredictably. The elevator controls the pitch and you have unpredictable pitch motion. Seems you have answered the problem. Replace the elevator servo.
villapilote is offline Find More Posts by villapilote
Old Aug 06, 2013, 06:21 AM
Joined Aug 2013
I had the same problem
I had the same problem and it was my radio. I upgraded to a better radio and things are fine now.
Rob62 is offline Find More Posts by Rob62
Discussion Lazy Hawk - nose dive on launch - help jtm2003 Ornithopters 18 Jul 14, 2013 02:12 PM
Question XPS foam flying wing nose diving jobbie Foamies (Scratchbuilt) 17 Jul 03, 2013 08:52 AM
Discussion V911 nose dives? ebrammer252 Micro Helis 2 Feb 10, 2013 10:26 PM
Help! Nose diving on full throttle. Nose heavy??? Jam1e Electric Plane Talk 23 Feb 10, 2012 07:04 PM
Why a plane goes UP in a dive if it's NOSE heavy? Flying Cat Modeling Science 21 Sep 26, 2002 04:31 AM
