Old Jun 19, 2013, 05:34 PM
gravity is optional
Joined Jun 2012
Help!
Motor cutting out on Super Cub LP
Ok, so I have a dilemma. The motor in my Super Cub LP keeps cutting out at random times. It especially happens when I go 3/4 throttle or above. I cannot think of what the problem could be!
james0742 is offline Find More Posts by james0742
Old Jun 19, 2013, 05:46 PM
United States, CA, Hayward
Joined Feb 2013
What size prop is on it, and what is the state of battery charge when it happens?
supercubcv is offline Find More Posts by supercubcv
Old Jun 19, 2013, 06:01 PM
gravity is optional
Joined Jun 2012
It is using the stock prop, 9X6? It happens no matter how much the battery is charged, does it through the whole flight.
Old Jun 19, 2013, 06:13 PM
Joined Feb 2013
Is the anti crash system still hooked up?
Old Jun 19, 2013, 07:38 PM
gravity is optional
Joined Jun 2012
No, I have it turned off.
Old Jun 19, 2013, 08:07 PM
United States, NJ, Pennsville
Joined Feb 2008
Do you lose just motor or all control (servos)?
stemo99 is online now Find More Posts by stemo99
Old Jun 19, 2013, 08:12 PM
gravity is optional
Joined Jun 2012
I just lost the motor.
Old Jun 19, 2013, 08:44 PM
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
They still use the garbage tamyia connectors on these? If so ditch it.
1320fastback is offline Find More Posts by 1320fastback
Old Jun 21, 2013, 03:28 AM
Joined Feb 2013
No, it comes with an ec3. I am pretty sure this is an esc problem if you're sure the batteries are charged up.
Old Jun 21, 2013, 07:48 AM
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
you're probably reaching the automatic low voltage cutoff.
You can disable this feature in your ESC programming... Hopefully.
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old Jun 21, 2013, 10:26 AM
wattman's Avatar
Evansville Dress Reg., Indiana, United States
Joined Jun 2004
Easy and quick check , use a different battery and see if it continues to act up .
Then replace the brushed motor with a new one , and if it still acts up , call HH for more help and replacement esc / receiver .
wattman is offline Find More Posts by wattman
Old Jun 21, 2013, 11:30 AM
turn, turn, turn.
Joined Oct 2005
I always push my batteries, and I always have my low voltage cutoff disabled.
Old Jun 21, 2013, 03:24 PM
United States, AL, Tuscaloosa
Joined May 2013
Had the same problem on my SC LP
Mine turned out to be the battery. Specifically, it was a breaking solder joint in the EC3 connector. It only reared it's head at nearly full throttle and would cut the motor (note I had the floats and larger prop on at the time, too, so more draw). I noticed it when removing the battery (cable a bit loose and partially pulling away from the conenctor).
I put it on the bench & cut the cable down, got a new EC3 connector and re-soldered. Good as new and hasn't happened since.
I still don't have the experience to tell you exactly what happened electrically that would cause the motor to cut (yet the controls to retain functionality), but hopefully it's worth something - at least a battery check. Best of luck.
BamaWade
BamaWade is offline Find More Posts by BamaWade
Sold Hobby Zone Super Cub LP ESC/Motor/Gearbox 2.4Ghz Spektrum DSM receiver/ACT sensor justplainold Aircraft - Electric - Power Systems (FS/W) 7 Feb 24, 2013 04:37 PM
Discussion Horizon Super Cub Lp motor cutting out tenrozzero Electric Plane Talk 7 Jan 29, 2012 02:17 PM
Discussion need help with motor/servo cut out on a super cub lp bringit3001 Beginner Training Area (Aircraft-Electric) 18 Apr 14, 2011 11:09 PM
Discussion Switch out the receiver on Super Cub LP BNF BrettKS Parkflyers 1 Sep 02, 2010 02:29 AM
Discussion Super cub vs Super cub lp vs super cub lp bnf vs easystar. xxxvizard Beginner Training Area (Aircraft-Electric) 12 Jan 06, 2010 03:02 PM
