Old Mar 20, 2013, 06:47 PM
You looking at me?
Ed Franz's Avatar
USA, KY, Burlington
Joined Sep 2001
Some motor help please
Hi there, I need some motor advice/ help for all you out the with a motor/prop/ amp calculator .
I pulled my Plettenberg HP 220/15 A1 P6 with a 7-1 gearbox out of an old 7 cell LMR. I would like to use it in my new 3 meter ALES plane. Can some one give a good starting point prop and amp wise for 2 and 3 cells packs? Maybe even a four cell if that's what it takes.
Ed
Ed Franz is offline Find More Posts by Ed Franz
Old Mar 20, 2013, 07:24 PM
John Lueke's Avatar
Miamisburg OH
Joined Dec 2003
What prop did it use for LMR in the past, and what was the current?
John Lueke is offline Find More Posts by John Lueke
Old Mar 20, 2013, 07:59 PM
You looking at me?
Ed Franz's Avatar
USA, KY, Burlington
Joined Sep 2001
It has a 17X10 and I don't remember how may amps it pulled on 7 Nicads. I know that there is a 100amp ESC in it.
Ed
Old Mar 20, 2013, 08:33 PM
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
Ed,
Here is a link to the new eCalc. It does list some Plettenberg motors.
http://www.ecalc.ch/motorcalc.htm?ecalc&lang=en
Easy enough to plug in numbers and get results. Worth a try. It's free.
Preston
jaizon is offline Find More Posts by jaizon
Old Mar 20, 2013, 08:51 PM
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Ed,
I'd try a 3S 65C battery if you intend to use this for ALES. Then shoot for 125-150 watts per pound for whatever you are going to put it in. This should get you a good climb rate for ALES. If you need more, then 200 watts per pound.
JT
jtlsf5 is online now Find More Posts by jtlsf5
Discussion Need some info about radios-Pleas read mrhodes Radios 2 Feb 12, 2014 12:55 PM
Discussion tricopter problems pleas help swar Multirotor Talk 13 Mar 14, 2013 10:31 AM
Discussion Searching For some Plans Need some Help!! PeteFlyers3 Electric Plane Talk 5 Feb 22, 2013 04:59 AM
Discussion a gun control victims plea for help AustinTatious Life, The Universe, and Politics 11 Feb 20, 2013 04:39 PM
Discussion A little help pleas EDP300 motor system??? Majortomski GWS (Grand Wing Servo) 2 Mar 26, 2008 08:01 AM
