Old Nov 10, 2014, 02:05 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Problem with the car is the ground plane created by the roof. If your "compact GS" place the antenna 24" above the roof, then yes.
-Hugo
Hugeone is offline Find More Posts by Hugeone
Old Nov 25, 2014, 10:27 AM
Hi Hugo
Made a 5.8 turbine
I used 0.6mm wire, do I need to adjust lengths to suit as I know your tutorial states 0.5mm.
Used these lengths :
Arms - 1.73" 43.94mm
1st - 1.077" 27.36mm
2nd - 0.743" 18.87mm
Center - 0.229" 5.82mm
Can I adjust the center spacing to suit as the first one is already built to your 0.5mm 5.8 specs.
I can only find 0.6 and want to build another in 0.6 gold plated memory wire.
Want to use these for 250 carpark racing as we get really bad multipathing at the mo with spironets.
Thanks Chi
chilau is offline Find More Posts by chilau
Old Nov 25, 2014, 10:11 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Nice job here.
Multiply by 0.987, but the bandwidth is wide enough not to worry about that.
You can also use upper end channels.
-Hugo
Discussion Lawmate 1.2ghz and CP antennas? Does it work. airbagit13 FPV Talk 23 May 20, 2011 07:58 AM
Question upgrade from fp to cp kkfd Electric Heli Talk 2 Apr 08, 2011 08:28 PM
Sold 2 New - TrueRC 900mAh 11.1V 3S1P (Blade CP) SOLD simages Aircraft - Electric - Batteries & Chargers (FS/W) 3 Sep 17, 2008 03:16 PM
New 11.1V 15C 2200mAh packs from TrueRC supi7 Batteries and Chargers 17 Nov 30, 2005 05:55 AM
F/S New powerfull cells and packs from TrueRC supi7 Product Announcements 8 Oct 07, 2005 12:47 AM
