Closed Thread
Old Dec 01, 2012, 11:25 AM
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Im sorry if this is too much off the topic here but I cant find answers elswere.
Im recording with #16, transfer files to windows movie maker and once I cut unwanted piece of video it doesnt play any reminding piece (black screen with sound).
If I transfer the file to Corel Video studio I can cut all I want but then once I touch the file the video skips frames :-(.
I have two or three vids now I can not edit :-(( anywhere. Did not have this problem with file from FPV cam or older #16.
Do I need to convert to some different format first?
nakelp86 is offline Find More Posts by nakelp86
Old Dec 01, 2012, 12:01 PM
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
This is the #11 thread, you need the #16 thread.
IF you read posts 1,2.3 & 4, There, they will givr you a lot of help, as the symptoms described are known problems with work- arounds.
empeabee is offline Find More Posts by empeabee
Old Dec 01, 2012, 12:03 PM
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
First, are you using the old XP version of MM? It sounds like you are using the .AVI file version of the #16 firmware, which saves non-standard AVI files that does exactly what you describe with some of the less capable editors. The MOV format version doesn't have this problem, but may have other for some editors.
I suggest you read the large discussion on editing at the beginning of this thread (post #3?) or in my #16 thread (you are posting in the #11 thread here, so the #16 is off topic (but has the same issues with editing).
Tom Frank is offline Find More Posts by Tom Frank
Old Dec 01, 2012, 12:09 PM
KK6MQJ
Bajora's Avatar
Joined Sep 2004
Filmed this one using my keychain camera and a RCLogger RC Eye One quad
Aerial Video using KeyFob Camera on RCLogger Microquad
Bajora is offline Find More Posts by Bajora
Old Dec 01, 2012, 12:41 PM
Nakelp
nakelp86's Avatar
Joined Sep 2004
Thx and again sorry for diverting the thread but I am getting desperate
Sorry and thank you Tom
Old Dec 01, 2012, 05:08 PM
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
I've just stripped an old #11 down to 6.7 grams to go on a micro quad:
The main weight saving is by running the camera off the quad's cell, at the moment though the camera shuts down at 2:20 although the quad doesn't show LVC till just over 6 mins. I will try some better cells that may drop less voltage under load - worst case it will easily handle the weight of a second cell just for the camera if nesc.
Only done a quick test indoors in dim light (worst conditions for a #11 ) - pretty impressed with the lack of vibration. 30 second extract (turn the sound down - I must disconnect or tape over the mic ):
X4test (0 min 38 sec)
Bill Glover is online now Find More Posts by Bill Glover
Old Dec 04, 2012, 06:56 PM
Joined Apr 2012
strange noise
Hi everyone,
I have had this problem several times with #11 and #18 cameras, and now I have finally found some time to record a sample video and show you the problem.
The video posted below is a sample clip extracted from a +1h longer video recorded with my #11 camera. At the beginning the video was perfect considering that it is taken inside my room. After a while, a noise appeared on the right and get more and more intense during the video. At the end, the video was completely ruined. What happened?
problem with #11 (0 min 0 sec)
ginetto
ginetto is offline Find More Posts by ginetto
Old Dec 04, 2012, 07:22 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Originally Posted by ginetto View Post
Hi everyone,
https://vimeo.com/54899227
ginetto
Your video link did not work, but based on your description, that is the "classic" artifact of a battery that is running out of juice. Normally the camera should stop recording before that happens, but obviously yours does not.in it's
Old Dec 04, 2012, 07:36 PM
Joined Apr 2012
The Vimeo is still processing the video.. You can see this other video recorded with #11 version 2.
Noise (0 min 29 sec)
Here, I had the same problem but smaller.
I do not think it a problem of battery, because the noise (a brighter area on the right) became visible after 2 minutes and it increases for +1 hour.
Old Dec 05, 2012, 05:43 AM
Joined Nov 2010
https://vimeo.com/46286418
Mtz also had this problem with his #16, albeit not nearly as bad.
A member on the #16 thread suggested the problem could be with the CMOS lens module overheating, which I believe is very logical, especially since we now know this problem also occurs with the #11 / #18.
The only other possibility is that light could be entering into the rear of the CMOS module. If the camera case is intact, and no LED is on during recording, I think we can rule out this possibility.
The only solution is to purchase a new lens module or add additional cooling. If the camera is new, I suggest you contact the seller for a replacement.
From what I have read in the #16 thread, the problem only seems to appear when the cameras record over a long period of time.
Isoprop is offline Find More Posts by Isoprop
Old Dec 05, 2012, 07:38 AM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
OK, After seeing that I agree it's not the low voltage breakdown, which results in a very jagged breakdown in the picture edge and is accompanied by an intermittent buzzing sound. The image breakdown and buzzing gets worse as the battery becomes more and more depleted.
I think the most plausible cause is mentioned in Isoprop's post, but this doesn't happen in bright light outdoors on a hot sunny day. Indoors in low light such as your example makes the CMOS imager work a lot harder, though, both in long electronic shutter times as well as boosted gain on the CMOS, both of which should generate more heat, I think. But why that would affect the right side of the CMOS more than the left is a bit of a mystery, unless it's because the DSP chip also generates a LOT of heat and it resides on that side of the circuit board and is contributing to the heat issue on the imager.
Old Dec 14, 2012, 12:37 AM
Joined Dec 2012
808 camera motion detection sensativity
I have been using the n616setup program by isoprop which is great.
I have the #16 camera with teh version 49 mov software..
There is a motion sensativity of hi or low which does not work..
anybody have an answer for this..
mcansea is offline Find More Posts by mcansea
Old Dec 14, 2012, 03:34 AM
Joined Nov 2010
Well, first of all, you've got your threads confused This is the #11 thread. The only utilities I wrote for the #11 were for the accurate time setting, but that was a very long time ago!
Now back to your #16. Motion sensitivity was only introduced after v0.49, so you'll have to update your firmware to v0.53 if you need that functionality. As you have noticed, parameters that are not valid for the installed firmware version will always be disabled in the GUI.
Old Dec 17, 2012, 05:59 AM
Joined Dec 2012
Hi, i am new here and want to ask if this version #11 supports motion detection and time lapse recording? Thanks
massimopaolo28 is offline Find More Posts by massimopaolo28
Old Dec 17, 2012, 08:16 AM
Joined Nov 2010
Motion detection and time lapse are a conflicting pair, so you can't combine them.
Both motion detection and time lapse work separately.
The #11 only supports time lapse of 10, 20 or 60 seconds. If you want a wider range (from 0.5 sec. to 60 secs.) then the #16 is the better choice.
You also have more control over motion detection on the #16 (duration and sensitivity), but you also cannot combine the two, for obvious reasons.
If you don't already have a #11, I strongly suggest you take a look at the #16 thread. The #16 is by far the most versatile and supported camera in the 808 size.
Closed Thread
Video Samurai with key cam AeroNut45 Electric Plane Talk 2 Oct 31, 2010 12:40 AM
Found found beladog FPV Equipment (FS/W) 1 Oct 30, 2010 02:01 PM
Discussion Any sign of True real time HD FPV gear....not secondary HD CAM ???!! khaled_abobakr FPV Talk 8 Oct 10, 2010 08:13 AM
Mini-Review Key Chain Cam for your autogyro!!! imsofaman Auto Gyros 7 Sep 10, 2010 08:10 AM
