Old Jan 01, 2011, 06:02 PM
Were..is..my..Super..Suit ..
j3tman's Avatar
United States, NE, Papillion
Joined Sep 2009
Just ordered mine!!!!
j3tman,
j3tman is offline Find More Posts by j3tman
Old Jan 01, 2011, 06:39 PM
fredmdbud's Avatar
USA, MD, Frederick
Joined Jan 2010
j3tman,
Welcome to the club!
fredmdbud is offline Find More Posts by fredmdbud
Old Jan 01, 2011, 06:52 PM
T-CAT's Avatar
Joined Aug 2008
j3tman,
Very cool! What color scheme?
T-CAT is offline Find More Posts by T-CAT
Joined Nov 2005
If you can make the plane out of some good quality 1.3 or 1.9 epo then this thing will sell itself.
Is there an time estimate on the 90mm kit only?
Regards
erh7771 is offline Find More Posts by erh7771
Old Jan 01, 2011, 09:32 PM
j3tman's Avatar
Joined Sep 2009
Blue angels, should help me see it in the air when im doing 50,000mph
j3tman,
Old Jan 02, 2011, 12:36 AM
"Aircraftus Fragmentum"
kydawg1's Avatar
United States, MI, Detroit
Joined Mar 2007
Originally Posted by Andy chen View Post
Thank you all of your suggestions.
YES, I have been concerned this thread.
About landing gear, I think I should take some pictures after holiday. it is a very simple question.
Of course in the future I would try to do better. Because I can't make perfect F - 18.
If you know. Four years in the past, this is my fourth F - 18, if you have purchased before or a concern. You will know that I have been trying to make better. I'm sure you'd agree with my efforts.
With regard to price, concerning the quality is a difficult balance things.
I'm not a really businessman. I'm just a guys who is doing to realize the dream
I love F - 18
Believe in the near future you will see a 90MM F - 18
Landing gear including doors are automatic operation, the factory has been installed at all.
I have a basement full of ANDY CHEN designed planes.....gonna need the 90mm F18 too. Can't wait.
kydawg1 is offline Find More Posts by kydawg1
Old Jan 02, 2011, 04:50 PM
Monsterou
Joined Oct 2008
Originally Posted by RugFlyer View Post
OK I stand corrected it's not toe out, but it's also not "squat spread" or "straddle.
The correct term is "negative camber". That's what I'll be adding to my main gear struts for a for better scale appearance & a more stable track.
Bajora...Congrats on the successful maiden & following flights, keep the pics & videos coming!
Oh, HAPPY NEW YEAR EVERYONE!
Hi, anybody who has the plane already, is it possible to adjust to positive chamber on the stock retracts? If you're going to mod the landing gear stance making it wider to make it more scale, wouldn't you want positive camber on the wheels to get the wheel sitting vertical when is under load?
Monsterous is offline Find More Posts by Monsterous
Old Jan 02, 2011, 07:12 PM
McLean, VA
Joined Dec 2001
Bajora,
Thank you for the excellent preview of this long awaited F-18. Working retracts and trailing links! Amazing. Mr. Chen, you have trumped the industry.
Now, just some questions for Bajora,
What process did you use for removing the gray and red paint from the mating surfaces at the glued joints? (wings, stabs, and fins to fuse)
Does the paint sand off easily, or is there a solvent that can be used?
Just asking because I assembled a Nitro/MaxJet F-18 and the rubbery paint was a 2 hour PITA to remove by sanding, slicing, and peeling.
What adhesive did you use to attach the wings?
Thanks in advance!
Jim
Jim Blanchfield is online now Find More Posts by Jim Blanchfield
Old Jan 02, 2011, 08:12 PM
KK6MQJ
Bajora's Avatar
Joined Sep 2004
Jim, I used a emery board type of abrasive stick to sand the mating surfaces, much like your wife uses on her nails? (Trust me ... don't grab hers, go to the beauty supply and get your own!) I thought it came off pretty easily. I used five minute epoxy to attach the wings, vertical stabs and horizontal stabs. I did not think there was a complete coat of the paint on most of the mating surfaces ... as this photo of the verticals shows? Almost like they tried to avoid painting the mating surfaces in production? I poked wee holes in the wing and fuselage roots, into which the epoxy could ooze.
Bajora is offline Find More Posts by Bajora
Old Jan 02, 2011, 08:25 PM
j3tman's Avatar
Joined Sep 2009
Does anyone think they will add flaps or slats to theirs?
j3tman,
Old Jan 02, 2011, 08:28 PM
T-CAT's Avatar
Joined Aug 2008
I thought about that, but every F-18 I've flown comes in stable, and relatively slow. It would be too much of a hastle to make it worth while for me. It would look cool though.
Old Jan 02, 2011, 08:29 PM
j3tman's Avatar
Joined Sep 2009
I see what you mean, i guess it would just be for the "cool" factor
j3tman,
Old Jan 02, 2011, 08:45 PM
KK6MQJ
Bajora's Avatar
Joined Sep 2004
As mentioned, this one is already SO light and slows so nicely ...
I just went out and weighed mine:
34 ounces for the airframe + 8.5 ounces for the 4S 2250s I flew in it = 42.5 ounces AUW
Old Jan 02, 2011, 08:55 PM
Dyess AFB
Joined Apr 2009
Bajora, what would you say your flight times are on the 2200's? I only got 3:30-4:00 minutes on the Mig-15 using 2200's. I went up to 2650's and got more power and close to a minute more flight time with just a slight increase in weight. If there's room I want to try some 3600's with a sapac MB-1 combo (1000 watts baby!)
Matt Howard is offline Find More Posts by Matt Howard
Old Jan 02, 2011, 08:56 PM
T-CAT's Avatar
Joined Aug 2008
Bajora, I plan to make mine a 5S set-up. In your observation, is fitting a 3300 5S pack possible? It looks like it would be if the little tabs of foam are carved away in the battery bay. Also, would it be possible to actually balance the jet with a 5S pack even when moved as far aft as possible? You wouldn't have a 5S pack to try balancing the jet with, would you?
Discussion New! $129 Nitro Planes Rc Landers 70MM F-16D EDF Jet With Retracts FlyBoyTha1 Foamy EDFs 49 Jun 20, 2009 05:58 PM
Discussion Starmax/Exceed RC/Topgun F18-C 70mm what Fan does it use? Stuart B Foamy EDFs 0 May 16, 2009 12:39 PM
New Product New!!! Exceed RC F-22 Raptor 70mm Ducted Fan RC Jet nitroplanes Nitro Planes 9 Apr 19, 2009 08:06 AM
Cool *** UPDATE *** New Version 2 70mm Exceed RC F/A-18C EDF Jet + NEW MOD VIDEO nitroplanes Nitro Planes 2 Mar 20, 2009 05:57 PM
