Old Oct 26, 2010, 08:28 PM
FPV Pilot
ttucker's Avatar
United States, OR, Beaverton
Joined Mar 2008
Poor man's altitude indicator
I've seen some pretty ingenious things invented for helping with FPV flight, bank, pitch and stall indicators, but has anyone come up with a simple altitude indicator that dosen't need to be through an OSD? I'd love a simple and cheap altitude indicator solution I can mount on plane's dash. I guess they're all based on barometric pressure so that means it can't be too homemade? Any ideas out there to share?
ttucker is offline Find More Posts by ttucker
Old Oct 26, 2010, 08:33 PM
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
I use/used a bubble level. You can see it pretty well through the camera
ashdec87 is offline Find More Posts by ashdec87
Old Oct 26, 2010, 08:34 PM
FPV Pilot
ttucker's Avatar
Joined Mar 2008
Yea, I got the bubble level going, I'm looking for altitude solution though.
Old Oct 26, 2010, 08:42 PM
ashdec87's Avatar
Joined Feb 2004
ohh I read attitude
Old Oct 26, 2010, 09:25 PM
FPV Pilot
ttucker's Avatar
Joined Mar 2008
What are you talking about?
Old Oct 26, 2010, 09:30 PM
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
maybe something like this
http://cgi.ebay.com/Hiking-Digital-A...#ht_6122wt_905
mkmkmk13 is offline Find More Posts by mkmkmk13
Old Oct 26, 2010, 11:35 PM
FPV Pilot
ttucker's Avatar
Joined Mar 2008
Yea, this is excellent except for weight. I think this is around same as a 1800 ma battery pack. Darn.
Old Oct 27, 2010, 01:17 AM
Expat
Japan
Joined Apr 2010
Attitude = position relative to horizon -> bubble level
What are all these other poor man's indicators you're talking about?
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Oct 27, 2010, 03:04 AM
The simplest, the better!
pdemon's Avatar
Italy, Europe
Joined Apr 2002
This may be what you are looking for: http://www.hexpertsystems.com/zlog/
Attitude DIY and Zlog altitude indicators...
FPV equipment testing #1 (2 min 8 sec)
pdemon is offline Find More Posts by pdemon
Old Oct 27, 2010, 03:40 AM
Joined Feb 2005
ttucker,
you could try to get the altitude part of this:
http://www.thefind.com/sports/browse...inox-altimeter
It's fairly small and light, if you can find one.
Mlke
mike in az is offline Find More Posts by mike in az
Old Oct 27, 2010, 04:40 AM
QUIKSILVER's Avatar
UK
Joined Sep 2002
I modded my Zlog
Have a look here:
http://fpv-community.com/forum/showt...highlight=zlog
i used a small round mag glass and made my own dash...
let me know what you think
QUIKSILVER is offline Find More Posts by QUIKSILVER
Old Oct 27, 2010, 11:26 AM
FPV Pilot
ttucker's Avatar
Joined Mar 2008
Thanks for the info guys. I've seen reference to the Zlog device and thinking about getting one, but is it stand-alone? Is something else required with it to continually display instantaneous altitude? Otherwise it just logs max altitude points during flight, right?
Of course I have the usual wet ball compass (see attached pics) I mounted in my Easy Star nose that, in addition to heading, does a pretty good job of pitch and roll indications, when referencing against the white line around the middle of the ball. I also added the mylar stall indicator. All works pretty good but I'd really like some indication of altitude.
Old Oct 27, 2010, 12:06 PM
Expat
Japan
Joined Apr 2010
That's a great idea with the ball compass! I 'll try that now.
How does that Mylar stall indicator work exactly?
Old Oct 27, 2010, 12:09 PM
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
No, It is stand alone and has a digital readout. Real time updating.
The Z-Log is great!
I have one.
Unfortunately it is out of production...
galaxiex is offline Find More Posts by galaxiex
Old Oct 27, 2010, 12:22 PM
FPV Pilot
ttucker's Avatar
Joined Mar 2008
Yea, I actually saw both ideas on the FPV forum somewhere. Its critical to get a really good quality wet ball. I bought too cheap of one initially and it tended to hang up inside the ball casing, not giving dependable readings. The one I have now (still only $7) moves very smoothly and reliably and is in camera field of view when looking forward in default flight mode.
The mylar stall indicator is so simple its complex. This is simply a piece of thin mylar (most any similar material will work) attached at the trailing edge. When air is moving over it, the strip bends upwards in your field of vew. When air is not moving over it, i.e. near stall, it tucks back down against the nose of plane. Obviously, not good for accurate air speed indicator, but does give simple, quick indication of how close you might be to stall. I haven't fully tested mine yet, and might be somewhat annoying, bouncing around in field of vew, but simple to remove if that is the case. See following clip:
Stall indicator is added. (5 min 55 sec)
Discussion 4g3/Novus CP - A Poor Man's Heli - Major Problems Solved Tread jdog83 Micro Helis 39 Oct 29, 2010 01:10 PM
Poor Man's Heat Shrink for Homemade Battery Packs... flytowner Parkflyers 28 Mar 13, 2010 12:45 AM
Poor man's Super Slow Stick fun flyer? uglyplane Parkflyers 1 Jul 03, 2003 12:54 PM
Kyosho 180 Poor Man's Power Fix??? Don Sims Electric Plane Talk 41 May 12, 2001 10:23 PM
