Old Sep 11, 2009, 10:35 PM
Joined Sep 2008
gws r-4pll and jr radio not works! :(
HellÚ, i have a small problem, today i received the GWS R4-Pll in 75mhz
i have ordered the um 1 size crystal for receiver 75.550 mhz and a tx crystal in 75.550 mhz
I have a JR XR3i in 75mhz, and today i have tryed to connect but the radio and the receiver not comunicate!
where is the problem? i have tryed to insert the gws 75.550 mhz with your um1 75.550 and the original JR crystal in 75.550 in the radio but not comunicate
I have tryed to put the 4.8v in the 4/b channel and a servo in second or first channel, the servo is on but not response at the command of my jr radio
I dont know if my radio is PPM or PCM, i think ppm
I have a GWS R4-Pll wirth vertical pin FUTABA style, but the futaba style is
the problem for my jr radio? or
maybe I should take the receiver with the inscription JR STYLE?
very thanks!
Chris
Maylord is offline Find More Posts by Maylord
Old Sep 11, 2009, 10:43 PM
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Let me pass this thread to GWS RD team.
Some RX X'tal run at lable frequency +455Khz, but some define at -455KHz.
Yet, dual conversion will even run at -10.7Mhz!
Also, some will run at 1/2 or 1/3 tone...
Have to check X'tal chat for details.
GWS4CEO is offline Find More Posts by GWS4CEO
Old Sep 11, 2009, 11:00 PM
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Here we have information from RD:
[10:57:31] GWS RD MARK said: R4PII must use JR type for JR PPM TX.
Old Sep 11, 2009, 11:24 PM
Joined Sep 2008
ok, the correct code of receiver is GW/R4PII75/J right?
Old Sep 12, 2009, 12:24 PM
Taipei, Taiwan
Joined Oct 2005
Yes, the receiver is in JR shift, and it's better to use GWS Rx crystal on this R4PII, and the JR Tx crystal on the JR Transmitter.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Sep 15, 2009, 06:28 PM
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
DO NOT USE ANY OTHER CRYSTAL IN A TX OTHER THAN THE MANUFACTURER'S.
You may get away with it but it a very poor practice and may create some bizarre problems.
In the USA it is technically illegal by FCC rules for anyone other than a qualified technician to change transmitter crystals. Obviously, it's easy to do, just plug a new one in. But the TX needs to be tuned to the Xtal.
Best not to go there.
flydiver is offline Find More Posts by flydiver
Old Sep 15, 2009, 07:31 PM
Joined Sep 2008
Thanks for you reply, but sorry if I use the rx gws um1 size in the rx e the jr tx crystal in the transmitter in theory i don't have problem right?
In Italy the 75mhz is illegal, but i'm not very very sure
sorry for my english,very thanks!
Old Sep 15, 2009, 10:29 PM
flydiver's Avatar
Joined Jan 2007
Yes, UM1 in the RX and JR crystal in the JR TX should work as long as they are on the same frequency and channel.
Old Sep 16, 2009, 01:13 AM
Taipei, Taiwan
Joined Oct 2005
Hi Maylord & Flydiver,
Yes, that's what I replied to your post earlier. And this way does not break the rule of FCC applied in USA. I did not try to encourge someone to use the Tx crystal other than the Tx manufacturer's one, Flydiver.
Chen
Sold gws r-4pll 4ch pico receiver and crystal nitrodude71 Aircraft - General - Radio Equipment (FS/W) 1 Jul 04, 2008 04:42 PM
Gws R-4pii Rx (jr) mohillbilly Non R/C Items (FS/W) 1 Sep 18, 2007 12:13 AM
Sold GWS R-4Pll/H RECEIVERS (2) CH 23 jerryj39 Aircraft - General - Radio Equipment (FS/W) 0 Feb 24, 2007 12:27 PM
Sold GWS R-4Pll Micro RX fuzzyhead Aircraft - General - Radio Equipment (FS/W) 5 Apr 30, 2006 01:43 PM
GWS R-4P Receiver jr shift 1987tc Aircraft - General - Radio Equipment (FS/W) 3 Dec 03, 2004 12:14 PM
