Old Nov 16, 2014, 12:04 AM
United States, NM, Farmington
Joined Dec 2006
MMW Carbon Micro-H
Well, saw the Micro-H quad at Micro-Motor-Warehouse and looked like a "mini-me" to my QAV250 so decided to get it and build it.
Here's what I went with:
Complete Carbon Micro-H Quadcopter
CL-0820-15 Motors
AlienWII Controller with LemonRX (OrangeRX Module on Taranis)
Turnigy Nano-Tech 750mAh 1S
55mm Hubsan X4 Props
Very simple to build and setup, just got to have some soldering skills. I took heatshrink to the wires since they are very small and didn't want them cutting on the carbon fiber. I heat shrunk them to the frame in all 4 corners to hold the wires down, trimmed the wires and soldered to the board. After the binding, it was pretty much ready to fly.
Used velcro to hold the batteries to the bottom. But had an issue with that because the quad would land on the bottom. I didn't want to put the batteries on the top because I plan on doing a Micro-FPV setup on it. So I designed and printed some feet that extended below the battery.
I may re-design the feet a little later on and move them further out towards the motor mounts. Right now they are just pressed on and glued with a little bit of CA onto the lower screw heads.
I haven't really gotten it outside to fly yet but it flies really well indoors, rate mode and horizon mode.
OsiViper is offline Find More Posts by OsiViper
Old Nov 16, 2014, 10:19 AM
United States, MD, Annapolis
Joined Jun 2013
I love that little frame but as Benedikt says its a little on the heavy side. Maybe some dark force editions would give it the power it needs etc. Looks nice thought about getting one myself soon
Waterbound is offline Find More Posts by Waterbound
Latest blog entry: Hubsan H107D Custom FPV Setup
Old Nov 16, 2014, 05:57 PM
I'm flying like a stone
Stone_Drone's Avatar
Spain, Region of Murcia, El Palmar
Joined Aug 2014
Hi all.
I introduce my MMW h frame.
Hubsan FC
1gr camera
Tx5823
MMW motors
Hubsan props
Stone_Drone is offline Find More Posts by Stone_Drone
Old Nov 16, 2014, 11:01 PM
Joined Jun 2013
Beautiful builds guys!
Old Nov 23, 2014, 11:42 AM
Joined Dec 2006
Put a TX5805 on mine.. gotta say this thing is a blast to fly FPV.. dont really have to worry about it as much as I do my QAV
Old Nov 25, 2014, 08:38 AM
What kind of flight times are you getting with that 750mah battery?
f1canuck is online now Find More Posts by f1canuck
Old Nov 25, 2014, 08:45 AM
Joined Nov 2012
Love these frames, great quality. Had some issues with the nuts coming loose though
Achi is offline Find More Posts by Achi
Old Nov 30, 2014, 02:37 AM
Joined Dec 2006
Was getting 5-7 minutes before VTX and camera, about 4-5 after.
Might need the stronger motors with the video gear.
Old Dec 04, 2014, 07:13 PM
Joined Jun 2013
There are two versions of the nanotech 750mah, one with additional JST and one without, the lipo without the JST is a bit lighter and is part number NE-BA931. I just picked up one of these from a buddy on RCG so looking forward to this thread growing and hopefully I can add something to the thread as well!
Old Dec 05, 2014, 11:27 AM
Joined Nov 2012
I just maidened my micro H. I made a couple of modifications over the stock for my own use. It flies very nicely
I used:
820-17 motors and Hubsan X4 props.
AlienWii and Lemon Satellite
Carbon Micro H frame (switched to all nylon from steel and saved about 4g on the frame)
I switched from the Micro-Losi Battery connector to a UMX connector and
I am using a Hyperion 1S 240mAh battery
All up weight is 42g
Update: flight time
Flight time around my apartment is 3:30 (measured over 5 flights) so pretty decent. Plus with the alienWii, it flies nicer than my modified Nano Qx frames.
Very Satisfied
I'm sure I could fly longer with a 750mAh battery, but I prefer lighter batteries myself and chose the UMX connector so I can use my UMX compatible batteries.
Old Dec 06, 2014, 02:10 PM
Joined Aug 2014
I was abducced to the dark force
Discussion Carbon Micro-H Build Need Help! digiorgior Scratchbuilt Multirotors 7 Nov 10, 2014 09:22 PM
Sold The Skyfish, Carbon Fiber Micro H Quad - Ready to Fly Skyfish Aircraft - Electric - Multirotor (FS/W) 7 Apr 05, 2014 10:18 AM
Sold Like new Carbon Fiber Micro-H Quad Setup for FPV PRICE LOWERED!!! baddb1 Aircraft - Electric - Multirotor (FS/W) 9 Mar 22, 2014 09:29 PM
Sold All Carbon Fiber Micro H Quad - Ready to Fly Skyfish Aircraft - Electric - Multirotor (FS/W) 10 Feb 15, 2014 10:26 AM
Sold All Carbon Fiber Micro H Quad - Ready to Fly ~ Sold Skyfish Aircraft - Electric - Multirotor (FS/W) 3 Jan 13, 2014 11:57 AM
