Old May 07, 2013, 02:24 PM
Joined May 2013
Need hep with corrosion removal on battery pack connection
Anyone know a good way to get rid of green corrosion on the male/female connections to the baterypack for a hitec radio?
Guess i shouldn't have flown off the wet field last year....problem is i live in Sweden where there aren't a whole lot of nice summer days.......Thanks
speedybanzai is offline Find More Posts by speedybanzai
Old May 07, 2013, 04:29 PM
Joined Aug 2002
Which Tx model?
Contact LHS or your local distributor direct, replacements for both individual cell connectors or the old removable
packs are available most areas.
Fastest and probably easiest, is to replace the connectors with a short heavy duty extension lead.
Cut and solder the female socket in place of the Tx pads and the male plug onto the battery pack.
Any other form of repair to old pads is doomed to unexpected failure.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old May 07, 2013, 04:50 PM
Florida
Joined Aug 2004
If this is the result of having some NiCad batteries rupture or leak, it is probably what is know as "black wire Disease". If so, where the wire itself has turned a blue/black or black color and become very brittle, it is an irreversable condition. The only solution is complete removal and replacement with new wire. if you go to www.hangtimes.com/redsbatteryclinic.html you will find a pretty good write up on "black wire disease".
Rodney is offline Find More Posts by Rodney
Question Cutting styrofoam, need more power. Serie connect two car battery charges nilshv The Builders Workshop 5 Mar 28, 2013 12:54 PM
Discussion Need ideas on connecting battery only charger to ac Jtupnsmoke Batteries and Chargers 4 May 14, 2010 04:00 AM
Discussion Battery connection/wing removal? adwb Electric Warbirds 6 Feb 19, 2008 09:54 AM
Discussion Need a little hep with my Optic 6 programming. Matt Chester Hitec/Multiplex USA 1 Jul 08, 2007 04:39 PM
Connecting two battery packs with a y-connector glide Batteries and Chargers 8 Apr 19, 2004 02:46 AM
