Old Oct 06, 2012, 01:01 AM
Hawaii
Joined Feb 2009
1/2 oz CF cloth
Why doesn't, or why can't, someone make a 1/2 oz CF cloth?
SHVentus is offline Find More Posts by SHVentus
Old Oct 06, 2012, 01:03 AM
Hawaii
Joined Feb 2009
Is CF that much heavier than FG?
Old Oct 06, 2012, 08:05 AM
R.M. Gellart's Avatar
Joined Nov 2005
There is a CF Scrim, the CL Stunt guys use it a lot for surface finish.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Oct 06, 2012, 02:37 PM
Hawaii
Joined Feb 2009
Marc,
What is it & where to get it.
Old Oct 06, 2012, 03:49 PM
Joined Nov 2005
At CST it is called cabon tissue or viel, they have it in .2oz/yd2 or .5oz/yd2.
Go to www.cstsales.com/carbon_tissue.html
Marc
Old Oct 06, 2012, 04:21 PM
Hawaii
Joined Feb 2009
Thanks Marc. I'll give it a look.
Old Oct 06, 2012, 06:04 PM
United States, FL, Shalimar
Joined Jan 2009
http://thayercraft.com/
jolly01 is offline Find More Posts by jolly01
Old Oct 06, 2012, 06:42 PM
Joined Nov 2005
Jolly, he is looking for carbon fiber cloth, not fiberglass.
Marc
Old Oct 06, 2012, 11:14 PM
United States, MA, Waltham
Joined Dec 2001
Half ounce carbon fiber cloth would be great stuff, but I've never seen any. Even better would be half ounce unidirectional carbon. The so called "tissue" is probably very nice for making a fine finish, but its mechanical properties are lousy, since the fibers aren't straight and the stuff is mostly air, which is replaced with epoxy.
CF is somewhat lighter than glass, as well as much stiffer. Typically 20mpsi vs. 6mpsi, if memory serves, but there are higher modulus versions of both.
lincoln is offline Find More Posts by lincoln
Old Oct 06, 2012, 11:52 PM
Hawaii
Joined Feb 2009
With such positive properties, and need/desire for it, why isn't somebody producing it? Instead of using light FG to "glass" a fuse, I'd like to use light weight CF to "fiber" a fuse. Somebody please start making it.
Old Oct 07, 2012, 01:21 AM
Joined Dec 2001
If you line up a million or so RC modellers, so you can order as much carbon as goes into an airliner, maybe they'll make the stuff for you!
If you make the wood part just a form, and have the carbon take the load, you could use the 2.4 oz carbon cloth that IS available. However, it would be far better to use two layers of unidirectional cloth.
I understand that the mechanical properties of spread tow may be somewhat better than regular woven cloth, and maybe you can get it in lighter weights, too.
Old Oct 08, 2012, 06:55 PM
Joined Jan 2009
Marc,
Sorry about that try;
http://shop.r-g.de/en/Reinforcement-fabrics/
Marc
Discussion Source of GOOD 0.75 oz cloth? GreenAce92_v2 Composites Fabrication 17 Jul 30, 2012 04:56 AM
Discussion 2 layers of .75 vs 1.6 oz cloth strength pitoniakmike Hand Launch 20 Jul 23, 2009 03:38 PM
Discussion Where can I get 1/2 oz fiberglass cloth jet_d Foamy EDFs 4 May 02, 2007 02:44 AM
Kevlar Cloth 2.1 Oz /YD For Sale glider34 Aircraft - Sailplanes (FS/W) 11 May 20, 2005 06:15 PM
