Old Mar 27, 2012, 04:03 PM
jpsabo's Avatar
Joined Feb 2011
Data
GemFan CF 11x4.7 and 12x4.5 props with Avroto motor
Just posted the static thrust test results for the GemFan carbon reinforced 11x4.7 and 12x4.5 props with the Avroto 770 kV motor.
http://www.flybrushless.com/prop/view/333
http://www.flybrushless.com/prop/view/332
All props tested to date with the Avroto are here: http://www.flybrushless.com/motor/view/615
A big thanks to flybrushless.com for keeping the database for these results!
Regards,
John
jpsabo is offline Find More Posts by jpsabo
Old Apr 21, 2012, 01:54 AM
Joined Jul 2011
:d:d:d:d
Originally Posted by jpsabo View Post
just posted the static thrust test results for the gemfan carbon reinforced 11x4.7 and 12x4.5 props with the avroto 770 kv motor.
all props tested to date with the avroto are here: http://www.flybrushless.com/motor/view/615
a big thanks to flybrushless.com for keeping the database for these results!
Regards,
john
chz109 is offline Find More Posts by chz109
Data Graupner Electro 11x5 prop data with Avroto motor jpsabo Multirotor Talk 3 Aug 03, 2012 11:13 AM
Data RCTiger Motor 900 kV with GemFan CF 9x4.7 jpsabo Multirotor Talk 0 Mar 14, 2012 10:20 PM
Sold 12 GWS 11X4.7 SF Props Opus44 Aircraft - General - Miscellaneous (FS/W) 1 Feb 28, 2012 07:45 AM
Discussion which 3 bladed prop is equal to 2 blade 11x4.7 prop? abcd123 Multirotor Talk 1 Feb 20, 2012 08:42 AM
FS: Graupner low-pitch props: 12x4 and 11x4, 5mm prop adapter kyril Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2004 12:16 AM
