Old Oct 19, 2014, 03:45 PM
Dave Pitman's Avatar
Joined Nov 2013
Thanks Guys, all very helpful information. I appreciate it!
Dave Pitman is offline Find More Posts by Dave Pitman
Old Oct 19, 2014, 04:43 PM
So. Cal.
Originally Posted by RedOctobyr View Post
Cool testing, Mark!
Thanks Red!
Here's some similar testing I performed when charging 6S packs...
http://www.rcgroups.com/forums/showp...9&postcount=61
You really want your input voltage at least 1V above or below the voltage range you'll be charging. And above is preferable. With higher voltage, the charger pulls fewer amps, which helps keep it cooler.
If charging at high current, you'll want the source voltage to be at least ~2.5 - 3.0 volts higher than the output voltage to compensate for charger and wiring losses. I've found that lowering the source voltage makes it easier to avoid the buck-boost transition, with negligible effect on overall charger efficiency.
When charging 3S packs at high current from an inverter generator, it's best to avoid ~12.5 - 15.0 volts. When charging 6S, it's best to stay at or below ~24.0 volts or above ~28.0 volts.
As Red clearly states, this poses no issue when charging from wall power provided you're not operating at the limit of your power supply.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Best charger/discharger $ can buy namancio Batteries and Chargers 30 Jan 31, 2010 02:52 PM
Power Pacer Battery charger/discharger ACE_McCOOL Batteries and Chargers 4 Oct 22, 2002 12:39 PM
NIB Hitec CG-325 Charger/Discharger/Cycler for 4-9 cells - $39! Jason M Aircraft - Electric - Airplanes (FS/W) 0 Oct 03, 2002 03:29 AM
WTB Good charger/discharger 10 + cells WickedFunRC Aircraft - Electric - Airplanes (FS/W) 0 Sep 05, 2002 08:55 PM
