Old Oct 01, 2014, 11:36 AM
United States, CA, SF
Joined Oct 2013
Need help adding FPV
Hey everyone
I have this quad X and want to know what the best FPV setup would be considering that it is made to lift from underneath, and would like to put a camera on the front or underside in front of the arms. Is there a way to put 2 camreas, so that one is pointing down, or using one camera only with a tilt? The reason is to check on the load being carried.
CAflying is offline Find More Posts by CAflying
Old Oct 02, 2014, 02:37 PM
Registered Loser
PeeMax's Avatar
Iceland, VestmannaeyjabŠr
Joined Aug 2011
Yes, just google "fpv cam switcher".
Very simple
PeeMax is offline Find More Posts by PeeMax
Old Oct 02, 2014, 04:44 PM
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
Beta testing for amazon delivery ?
You can also use a front facing camera and put it on a tilt driven by a servo. For other FPV equipement, you'll need a video transmitter (vtx) and video receiver (vrx) as well as a display like a monitor or goggles. Check the stickies for more basic info, lots to choose from dpending of what you want to do.
carguy1994ca is offline Find More Posts by carguy1994ca
Old Oct 02, 2014, 05:01 PM
Joined Oct 2013
I might use 2 cameras using the switcher but is there an easy way to make the osd do a picture in picture? That would be cool.
Old Oct 02, 2014, 05:07 PM
Quebec, Canada
Joined Sep 2006
Not that I know of.
Old Oct 02, 2014, 05:38 PM
Joined Oct 2013
Amazon cant handle this haha! Lol llll
Two transmitters is that a problem any suggestions?
I dont care much about the quality but low power.
Old Oct 02, 2014, 06:13 PM
Quebec, Canada
Joined Sep 2006
2 vtx and 2 cameras that send video at the same time is possible, as long as they are on different frequencies. You will need 2 monitors. More weight on the multi, would use the 2 cams on switcher approach. Lighter, simpler, less crowded multi.
Discussion Adding Ailerons to an Elevon'd F22 -need help with 9303 mix programming DesignGeek Radios 14 May 18, 2014 02:01 PM
Discussion Question on using sony nex5n for FPV (need ibcrazy help) remvideo FPV Equipment 0 Nov 18, 2013 08:22 PM
Discussion Need help with FPV plane... $100 (Upland, CA) crawlerjk FPV Talk 2 Nov 17, 2013 09:38 PM
For Sale Hoverthing FPV Entry-Level Setup RTF Everything needed minus FPV gear PICS ADDED satttheman Aircraft - Electric - Multirotor (FS/W) 3 Jun 29, 2013 06:59 AM
Discussion FPV lost radio - futaba 6ex 2.4 and FPV 900mhz - need help Luiz Werneck Foamies (Kits) 23 Mar 11, 2009 06:34 AM
