Old Dec 10, 2001, 08:06 PM
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
F86 question CP-1700 or CP-2400?
My F-86 needs a new 20 cell battery pack. The plane weighs in at 7 lbs even on a 430 sq inch wing with 20 2000 cells now. Power is a Midi Fan, Ultra 930-6 pulling close to 45 amps.
I am thinking of going to CP-1700 cells to reduce the weight, is it worth it or will I not notice it and I should just go with the CP-2400???
Comments anyone??
Ken
Ken Lapointe is online now Find More Posts by Ken Lapointe
Old Dec 10, 2001, 08:18 PM
2014 EDF JET JAM We be Jamming
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
I think I may be in the same boat. I took my F-15 out last weekend and the packs or that Aveox spinning thing is about to fail (again). At any rate I think I will go for 2400s. Since I like to taxi, takeoff and taxi back the duration will be a big plus. If it was a bungee bird then the 1700 would be my pick. Just my opinion.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Dec 10, 2001, 08:42 PM
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
It's a big plane, I would go with the 2400's... You would save about 11 oz, or 10% of your tot weight - not a whole lot.
I heard the CP-2400 have a slightly higher internal resistance than the RC-2400, don't have the Sanyo data in front of me right now...
Herb is offline Find More Posts by Herb
Old Dec 10, 2001, 08:51 PM
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
F-86
On my new Midi power F-86 I'm using 16 CP-1700's to start. I'm hoping for a ready to fly weight of 5 3/4 to 6 lb. There is no support wood in it except for the nose gear. I did not cut out the hatch out of the fus. This leave the fuselage not needing alot of internal bulkheads. The motor I'm using is a Hacker B50-18S with a Jeti 70-6-16 ESC.
Should fly in January.
Bob Ruff
PS The Hw 730 power version is flying great!
bruff is online now Find More Posts by bruff
Old Dec 11, 2001, 09:05 AM
Electriaddict
dorysch1's Avatar
Melville Saskatchewan Canada
Joined Mar 2001
Hi Bob you are running the same power system I am using except for the cells I have scr2400's Zapped and it flys pretty good and my plane weighs around 6.5 lbs this winter I am going to build a new wing to incorporate retracts I have a lot of wing area though 580 Sq Inches what is yours
dorysch1 is offline Find More Posts by dorysch1
Old Dec 11, 2001, 11:00 AM
Flying Welder Pilot
Plane Crazy's Avatar
Reno, Nevada
Joined Jan 2001
How does the plane fly at 7 lbs?
When I swapped from 20 2400s to 20 1700s on my lear jet with a weight savings of about 8.5 ozs, there was an enormous difference in performance and ROG distance. With durations of 4 minutes, no more.
But if the plane handles pretty good at 7 Lbs. Why not go for even more performance and put in a Hacker B50 18L and 25 CP 1700s, and keep the same weight. You will probably be glad for the shorter durations, so you have a chance to catch your breath after each adrenaline flight.
Gordon
Plane Crazy is offline Find More Posts by Plane Crazy
Old Dec 11, 2001, 11:42 AM
Electriaddict
dorysch1's Avatar
Joined Mar 2001
at my current skill level slow is good although more power is always good too! but I would have to buy another not cheap motor and controller the Jeti is limited to 16 cells perhaps in the spring I will build another faster style jet the tutor is a draggy design I will build one that can be bungee launched (microfan) the tutor loves the asphalt on takeoff it eats it up pretty good at least 200ft maybe 250
Early Testing (CP 1700 or HR 4/5 FAUP 1950) bitzerj Batteries and Chargers 11 Dec 06, 2002 08:09 AM
CP 1700 or HR 4/5 FAUP 1950 ? Al P Batteries and Chargers 1 Dec 05, 2002 05:18 AM
Twinjet batteries: cp 1700 or cp 2400 ? Al P Foamies (Kits) 6 Aug 21, 2002 05:00 PM
Which 2400's for EDF's CP's or SCR's ? Joe Elston Electric Ducted Fan Jet Talk 2 Mar 12, 2002 06:42 AM
CP 1700 Question JasonG Sport Planes 4 Dec 08, 2001 07:32 PM
