Old Oct 07, 2012, 08:19 AM
spaceinvader's Avatar
Princess Anne, Md.
Joined Oct 2006
brushless motor for gws pt-17?
Just pulled an unassembled GWS PT-17 out of storage. Wondering what brushless motor to use. Doesn't need to be speed demon. Scale flight or a little bit better. Any suggestions appreciated.
spaceinvader is offline Find More Posts by spaceinvader
Old Oct 07, 2012, 09:05 PM
Fly it low.. and fly it fast!
Hit N Run's Avatar
United States, MA, Westport
Joined Nov 2011
Go with a "400 class" brushless around 900kv
This should be perfect for you. Use a GWS 9X5 prop and you will be very happy. I would recommend 1000mah lipo packs to keep things light. If you want a little better flight time, go with the 1300mah. (use 3 cell packs with at least 20C rating)
Quoted from HeadsupRC's webiste.....
GWS EP9050: 25 ounces of thrust at 10 amps. Good choice for medium speed models.
It will be scale flying at around 2/3 throttle and probably unlimited vertical performance at full throttle... without being "stupid fast"
Hit N Run is offline Find More Posts by Hit N Run
Old Oct 07, 2012, 09:06 PM
Livermore, CA
Joined Sep 2004
Which motor did it have? The 350 or 400??
Butch777 is offline Find More Posts by Butch777
Old Oct 08, 2012, 07:32 PM
Taiwan, 北市
Joined Dec 2010
Its stock motor was brushed EPS400 with C gear if I recall it correctly. The said 400 class outrunner certainly works much better on it.
twn Chen is offline Find More Posts by twn Chen
Old Oct 09, 2012, 07:28 AM
Princess Anne, Md.
Joined Oct 2006
thanks
Thanks for the replys. brushless can be a little confusing. I found that HeadsupRc is a great source of products and info for newbies or old guys like me
Old Oct 09, 2012, 07:39 AM
Hit N Run's Avatar
Joined Nov 2011
You're only as old as you feel.
Enjoy life and live it to the fullest.
Discussion Brushless Motor suggestions for a GWS A-10 Warthog? RockChalkJayhawk Electric Warbirds 0 Aug 19, 2012 05:05 PM
Discussion GWS PT-17 opinions? Brushed versus brushless? rperego Electric Plane Talk 0 Feb 13, 2008 04:45 PM
Sold GWS Stearman PT-17 w/ motor & ESC: $60 OBO malibu43 Aircraft - Electric - Airplanes (FS/W) 1 Jul 17, 2007 05:32 PM
FS: GWS PT-17 brushless RTF!! davejfred23 Aircraft - Electric - Airplanes (FS/W) 11 Oct 09, 2004 09:39 PM
GWS PT-17 scale motor upgrade sparks Parkflyers 8 Nov 19, 2003 10:09 PM
