Closed Thread
Old Jul 17, 2012, 03:36 PM
high on flying since 2009
diekmann's Avatar
United States, MN, Barry
Joined Jul 2010
Help!
Hobbyking KK board help
i need some help before tomorrow if at all possible.
the situation:
tricopter with the 3.0 board flashed with any firmware just sits there and the tail servo jiggles a little bit. control input makes it do absolutely nothing, I can "arm" it but then it goes back to doing nothing........ i can plug the motors in to my receiver and they all spin up and the servo works too, just not through the board.
any input would be appreciated and if somebody can help me faster via a phone call or skype or something that'd be awesome
thanks
diekmann is offline Find More Posts by diekmann
Old Jul 17, 2012, 06:13 PM
diekmann's Avatar
Joined Jul 2010
anybody have input?
Old Jul 17, 2012, 07:27 PM
Hulk likes flying things
Phalanx-0's Avatar
United States, IN, Kokomo
Joined May 2008
ok, I'll bite.Have you calibrated the esc/motors?
If so then are the connections to the board from the esc's oriented properly?
Signal wire to the signal pin?
Phalanx-0 is offline Find More Posts by Phalanx-0
Old Jul 17, 2012, 08:09 PM
diekmann's Avatar
Joined Jul 2010
well i've tried calibrating but it doesn't do the normal beeping everybody else gets, it does it's same "i don't do anything business"
i know all the connections are good, i'm using redbrick esc's, i just thought of that, is that bad?
Old Jul 17, 2012, 08:45 PM
diekmann's Avatar
Joined Jul 2010
Flash the firmware from repository.
C:\Users\diekmand\Desktop\KK Multi\new kk control\lib\avrdude\windows\avrdude.exe -C C:\Users\diekmand\Desktop\KK Multi\new kk control\lib\avrdude\windows\avrdude.conf -p m328p -P usb -c usbasp -B 8 -e -U lfuse:w:0xe2:m -U hfuse:w:0xd9:m
avrdude.exe: set SCK frequency to 93750 Hz
avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update.
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude.exe: Device signature = 0x1e950f
avrdude.exe: erasing chip
avrdude.exe: reading input file "0xe2"
avrdude.exe: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude.exe: 1 bytes of lfuse written
avrdude.exe: verifying lfuse memory against 0xe2:
avrdude.exe: load data lfuse data from input file 0xe2:
avrdude.exe: input file 0xe2 contains 1 bytes
avrdude.exe: reading on-chip lfuse data:
avrdude.exe: verifying ...
avrdude.exe: 1 bytes of lfuse verified
avrdude.exe: reading input file "0xd9"
avrdude.exe: writing hfuse (1 bytes):
avrdude.exe: 1 bytes of hfuse written
avrdude.exe: verifying hfuse memory against 0xd9:
avrdude.exe: load data hfuse data from input file 0xd9:
avrdude.exe: input file 0xd9 contains 1 bytes
avrdude.exe: reading on-chip hfuse data:
avrdude.exe: 1 bytes of hfuse verified
avrdude.exe done. Thank you.
Flashing firmware from file.: C:\Users\diekmand\Desktop\KK Multi\new kk control\tmp\Tri16_SclStk4_M168.hex
C:\Users\diekmand\Desktop\KK Multi\new kk control\lib\avrdude\windows\avrdude.exe -C C:\Users\diekmand\Desktop\KK Multi\new kk control\lib\avrdude\windows\avrdude.conf -p m328p -P usb -c usbasp -B 8 -e -U flash:w:C:\Users\diekmand\Desktop\KK Multi\new kk control\tmp\Tri16_SclStk4_M168.hex:i
avrdude.exe: reading input file "C:\Users\diekmand\Desktop\KK Multi\new kk control\tmp\Tri16_SclStk4_M168.hex"
avrdude.exe: writing flash (4168 bytes):
Writing | ################################################## | 100% 2.42s
avrdude.exe: 4168 bytes of flash written
avrdude.exe: verifying flash memory against C:\Users\diekmand\Desktop\KK Multi\new kk control\tmp\Tri16_SclStk4_M168.hex:
avrdude.exe: load data flash data from input file C:\Users\diekmand\Desktop\KK Multi\new kk control\tmp\Tri16_SclStk4_M168.hex:
avrdude.exe: input file C:\Users\diekmand\Desktop\KK Multi\new kk control\tmp\Tri16_SclStk4_M168.hex contains 4168 bytes
avrdude.exe: reading on-chip flash data:
Reading | ################################################## | 100% 2.25s
avrdude.exe: 4168 bytes of flash verified
that's what i get when i flash. the sck part is what i need to fix right?
Old Jul 17, 2012, 09:40 PM
Phalanx-0's Avatar
Joined May 2008
no, just ignore that. everybody gets that
It appears that the flash was successful, your flight control board is now ready to talk to the esc's.
So, now you need to calibrate the esc's.
PLEASE REMOVE PROPS
1. transmitter throttle stick to full on
2. turn on transmitter
3. turn on receiver (plug in battery)
4. hear esc's beep
5. move stick to low position
6. hear esc's confirm beep
your esc's are now calibrated.
Old Jul 17, 2012, 09:54 PM
diekmann's Avatar
Joined Jul 2010
Holy ****
how did that not work the other 90 times i tried everything!? thanks so much for that, i can make the motors spin and they spin at diff speeds like they're supposed to! how do i reverse the yaw?
Closed Thread
Help! Hobbyking KK board reversing gyro help Foam boy Multirotor Electronics 23 Dec 08, 2012 12:13 AM
Sold Hobbyking KK board new - 10 shipped nemoskull Aircraft - Electric - Multirotor (FS/W) 3 Jul 05, 2012 01:37 AM
Discussion Hobbyking KK board Yaw problem dmcke5 Multirotor Talk 4 Mar 27, 2012 11:38 PM
Sold HobbyKing KK board v3.0 hththt Aircraft - Electric - Multirotor (FS/W) 1 Mar 25, 2012 11:52 PM
Discussion hobbyking kk board help. which way do polarities go? g3f0rc3 Multirotor Talk 1 Dec 19, 2011 11:07 PM
