Old Mar 11, 2012, 07:38 AM
I'm BIG on micros
Canada, ON, Brampton
Joined Mar 2011
Idea
"Amphibious" floats for micro floatplanes
Hi;
Just started work on some wheeled floats for my micro beaver. Post your ideas and suggestions so I can turn out a successful pair.
EDIT: Floats are going well, PM me if you want plans for the mod.
JSS4 is online now Find More Posts by JSS4
Old Mar 11, 2012, 08:24 AM
I'm BIG on micros
Joined Mar 2011
Coming along so far quite nicely. The pics are not the best, but then again my camera is not the best.
Main LG mount is custom bent wire
Old Mar 11, 2012, 07:08 PM
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
Not bad at all!!!
An alternative approach would be to carve the floats out of EPP. I always save some of the stuff when I buy a new electronic device or appliance that's packed in it.
Carve the floats, and if scale is important, cover with silkspan, rayon dress liner, or 0.5 oz FG cloth and then seal with water-based polyurethane (which is waterproof when dry).
Light, and unsinkable.
356Jim is offline Find More Posts by 356Jim
Old Mar 12, 2012, 08:36 AM
I'm BIG on micros
Joined Mar 2011
More progress. I had to run out to the LHS yesterday to get a UM J-3 tail wheel.
Tailwheel wire is slightly unbent to provide better ride height and shock absorbtion.
I am right now toying with the concept of rertracts.
How am I doing so far?
Old Mar 13, 2012, 06:08 AM
I'm BIG on micros
Joined Mar 2011
Got the bottom rear panels installed and front bottom panel is drying.
I had to use school glue after I realized that my CA wasn't foam safe
Old Mar 14, 2012, 11:03 AM
I'm BIG on micros
Joined Mar 2011
I have to get foam safe CA because white glue just doesn't hold.
Old Mar 24, 2012, 05:16 PM
I'm BIG on micros
Joined Mar 2011
NEWBEFLYER has the plans. Anybody else interested PM me.
Old Mar 24, 2012, 10:06 PM
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
Interesting, I've had a go at building the champ floats from plans on here, I was wondering about using wheels aswell, I'll have to keep an eye on this.
djdavies83 is online now Find More Posts by djdavies83
Old Mar 25, 2012, 04:41 PM
Joined May 2001
A friendly suggestion. Instead of using pins to hold the parts together while the white glue is drying, try narrow strips of painter's tape.
Also, if you have any water-based polyurethane finish (it doesn't matter if it's gloss, semi-gloss or flat), use it to seal the seams.
Wood glue, like Titebond III is waterproof.
Old Mar 26, 2012, 06:46 AM
I'm BIG on micros
Joined Mar 2011
Thanks, Jim.
I got foam safe CA yesterday and things really got going! One float is done, while I just need to cut out the rear panels for the other. First one weighs in at 4 grams.
These floats are wheeled only and will not land on water. I am however working on an idea for retracts which will make use of a 1.9 gram spektrum linear servo for the retracts. That probably won't come for a little bit.
My Beaver looks pretty good on semi scale amphibs
Old Mar 26, 2012, 05:14 PM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
looks likeitmay be possible without retracts....
Flying from water on amphibious floats (0 min 48 sec)
Old Mar 26, 2012, 09:01 PM
Pile-it
Alien_Tech's Avatar
United States, CA, Palmdale
Joined Nov 2007
http://www.youtube.com/watch?v=HEqL2mChJrI
Looking closely at the footage, they are retracted when landing, and let out again to taxi out. Neat footage!
Alien_Tech is offline Find More Posts by Alien_Tech
Old Mar 27, 2012, 08:54 AM
0.9g retracts
Yellow Baron's Avatar
3" from insanity, 2' from the computer ,Richford, Tioga county, Southern Tier, New York, U.S., North American Continent, Northern hemisphere, Earth, The Sol System, Milkyway Galaxy, The Universe, The Current Dimension, Your Selected Realm of Reality.
Joined Dec 2006
JSS4,
Will the floats support the plane's weight in water? Or is that why you stated that they are not for water?
Yellow Baron is offline Find More Posts by Yellow Baron
Old Mar 27, 2012, 09:25 AM
Yes, right there.
SpleenRippa's Avatar
Comox, BC, CAN
Joined Jul 2003
Originally Posted by JSS4 View Post
Thanks, Jim.
I don't 'get' the benefit of the extra drag incurred by the floats, if they can't be used to... Float...
SpleenRippa is offline Find More Posts by SpleenRippa
Old Mar 28, 2012, 06:33 AM
I'm BIG on micros
Joined Mar 2011
Spleenrippa, I am using the floats to cheat because floatplanes look better on floats than wheels. The beaver is one of them.
Also floats provide stability in flight.
YB, they are wheeled only because I can't do retracts of that type yet
Alien_Tech is right. Know what happens when a floatplane lands wheels down?
This:
Water landing with gear down (0 min 13 sec)
Wanted Parkzone Micro P-51 BNF or Micro F4U Corsair BNF FlgRC Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Mar 08, 2012 10:14 AM
For Sale Awsome power ! For your pz micro airplanes & micro 3d airplanes scharlach Aircraft - General - Radio Equipment (FS/W) 0 Oct 26, 2011 02:28 PM
Discussion micro heli's to micro planes cappy24 Beginner Training Area (Aircraft-Electric) 7 Oct 26, 2011 01:01 PM
Sold Team Novak 1875 Micro GT High Power Micro Racing ESC NEW! tprada1624 Cars - Cars and Parts (FS/W) 0 Oct 22, 2011 01:03 PM
Question ID 2 Amphibs gallfer Waterplanes 3 Apr 15, 2010 07:26 PM
