Old Oct 14, 2011, 06:54 PM
Tony Audsley Retired Locksmith
Lockey's Avatar
Australia, WA, Perth
Joined Sep 2011
Wires from ESC to Motor
Hi Guys, can anyone tell me what the 3 wires from the ESC to the motor are for, I know if I turn a couple round it will make the motor rotate in the opposite direction (can use on pusher with std prop)
The wires from the Motor are colours BLACK, YELLOW and RED but the ones from the ESC are all BLACK
CAN I GET THESE WRONG and do any damage?
Lockey
Lockey is online now Find More Posts by Lockey
Latest blog entry: Easy Autogyro
Old Oct 14, 2011, 07:28 PM
Retired and Lovin' it!
United States, KY, Sturgis
Joined Jul 2007
Lockey
In a word, no. Hook up all 3 wires, don't worry about colors. Run the motor. If it runs backwards, then reverse any 2 of them. Doesn't matter which 2 that you reverse, it will reverse the rotation of the motor.
Tony
tpfing is offline Find More Posts by tpfing
Latest blog entry: North Las Vegas 1971
Old Oct 14, 2011, 07:34 PM
Lockey's Avatar
Joined Sep 2011
Thanks Tony, just didn't want to screw the moter by doing the wrong thing
By the way, are you guys putting LONG wires onto the ESC to move up to the front on pusher designs?
Lockey
Old Oct 14, 2011, 11:21 PM
Ann Arbor, Michigan, United States
Joined Sep 2003
you'll see debate about long motor-esc vs long battery-esc. i follow what keith shaw has taught me... that it's better to extend the motor-esc and keep the battery-esc short. i don't understand the physics behind it, but apparently, with longer battery-esc wires, there is the potential for voltage spikes that can kill your esc. on the motor-esc side, if things get messed up, all that will happen is that the motor may not run smoothly, but you don't lose any of your components. with that being said, you'll see people all over doing one or the other or both. for the typical lengths that we use in our park jets, it probably doesn't make a whole heck of a lot of difference. for super large builds, it may start to play some role. just my 2 cents.
-beanie
beanie is online now Find More Posts by beanie
Old Oct 15, 2011, 12:50 AM
Lockey's Avatar
Joined Sep 2011
Thanks Beani, sounds feasible, cheers mate
Lockey
Old Oct 15, 2011, 07:14 AM
Australia, NSW, Plumpton
Originally Posted by tpfing View Post
in a word, no. Hook up all 3 wires, don't worry about colors. Run the motor. If it runs backwards, then reverse any 2 of them. Doesn't matter which 2 that you reverse, it will reverse the rotation of the motor.
Tony
nope but you should care at least center cable, from esc center cable should be motor center cable , rest red and black you can connect any site, see the air flow where you want ( backword or front)
aqkhana2002 is offline Find More Posts by aqkhana2002
Old Oct 15, 2011, 07:37 AM
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Incorrect. That does not matter at all. Hook them up, any order does not matter. If direction of spin is wrong then swap any two - just as he says.
And correct battery wires short - motor wires long is considered best for the health of your ESC when you need more wire.
Old Oct 15, 2011, 08:46 AM
Lockey's Avatar
Joined Sep 2011
Thanks Guys, I am almost ready to fly now
See: http://www.rcgroups.com/forums/showt...2#post19599792
Lockey
Question What wires on a Fiego motor correspond to ABC on a brushless ESC? zanek Racing Boats - Electric 22 Aug 12, 2011 06:38 PM
Discussion Which wires on ESC going to motor are positive/negative and signal wire? cannondale1974 Power Systems 11 May 15, 2011 09:57 AM
Discussion JST wires from ESC? garfro Micro Helis 1 Apr 24, 2011 09:13 AM
Question can I shorten the three wires from the esc to the motor? grfcon Power Systems 7 Jun 17, 2010 11:33 AM
Question Radio signal interference from motor/esc wires? Bob O Radios 2 Sep 27, 2008 08:18 PM
