Old Apr 15, 2003, 08:39 PM
Tullahoma, TN
Joined Jul 2000
Jeti ESC with UBEC Problem
My friend is using a brushed Jeti 50 and a UBEC. The brake on the ESC is set with a jumper so I'm thinking it's an older model ESC. The red wire on the ESC connector going into the receiver has been disconnected to disable BEC.
The problem is the ESC will operate the throttle regardless of whether the ESC switch is on or off. My buddy hoped that he'd be able to apply power to the UBEC to power his receiver and when he was ready for throttle, he would switch on the ESC. (I have a UBEC with a 70-amp BL Jeti ESC and that's the way it works for me.)
Does the ESC switch simply turn the BEC on and off? We don't think we have a short in the switch...any ideas?
Eric
EricBjorn is offline Find More Posts by EricBjorn
Old Apr 16, 2003, 12:11 AM
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
It sounds like the switch should be in the negative lead of the speed control-RX. This question is probably better suited for the "Power Systems" forum. I'll move it there for you.
GregG is offline Find More Posts by GregG
Old Apr 16, 2003, 01:15 AM
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
With the red wire disconnected, the ESC still gets power from the battery when connected.
The RX should get no power unless the Ubec is connected to the battery too, so the RX should not send a signal to the ESC.
Double check your connections, something does not sound right.
It sounds like you are trying to leave the battery connected when not flying and use the switch for an On-Off switch. Very bad idea!!
Fred Bronk is offline Find More Posts by Fred Bronk
Old Apr 16, 2003, 06:59 AM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
The Jeti's simply use the switch to interrupt the power going to the Rx. Without a Rx signal, the ESC will not run (you hope). So when you disconnect the red wire, you've effectively just turned off the switch. If the Rx has power from elsewhere, the ESC will work as if it was turned on.
Using any kind of switch to disable the motor is just a false sense of security. If the battery is plugged into the ESC, the system could fire up at any time. Don't plug in until you're ready to go, and then treat it with respect.
..a
Old Apr 16, 2003, 07:05 AM
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
The switch on the Jeti 50 only turns off/on the power to the RX; it between the BEC regulator and the RX connectors red lead.
In fact, you donít have to remove the red lead to the RX as long as you donít turn on the switch.
This info is direct from L.A. Johnson of Hobby Lobby, who also told me that you can use the Jeti 35 & 50 for a higher cell count 14 & 16 as long as you didnít turn on the switch. He suggested taping it off and stuffing it inside the fuselage.
jrb is offline Find More Posts by jrb
Old Apr 17, 2003, 05:14 PM
Tullahoma, TN
Joined Jul 2000
Assuming what jrw and Andy are saying is true, then we don't have anything wired wrong--everything is functioning as designed. We will certainly continue to treat the props with respect any time power is on the ESC and we do not connect the battery to the ESC unless we're ready to fly.
It's nice to get confimation of just what the Jeti ESC switch does--it switches power to the rx--and that's it. The ESC is powered and power could be delivered to the motor. Careful, everyone!
Now, how is the design different with a brushless Jeti ESC such that with a UBEC powering the rx, the motor won't turn until the switch is on?
Eric
Sold Hacker Master 70 amp opto esc with UBEC Steve H. Aircraft - Electric - Airplanes (FS/W) 1 Sep 12, 2005 06:55 PM
Problem with NiMh Pack & Jeti ESC LouG Power Systems 4 Jun 08, 2005 06:53 AM
Anyone using the Jeti esc with the switch? 1987tc Parkflyers 2 Mar 04, 2005 11:25 AM
Question Programing a Jeti esc with a Hacker programer Joe41 Power Systems 3 Aug 05, 2004 07:46 PM
Hacker Master 70 amp opto ESC with UBEC Steve H. Aircraft - Electric - Airplanes (FS/W) 2 Dec 26, 2002 10:55 AM
