Old Oct 12, 2012, 09:23 AM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
Hot Melt Glue High- Med - Low Temp - Confusion?
I'm new to using hot melt glue on foam models.
I have an Arrow brand single temp hot melt gun and Arrow brand glue sticks that are labeled High/Dual/Low. I have been advised to use low temp glue on foam. Does that mean I need a low temp glue gun, are the glue sticks I have ok to use on foam or do I need special low temp glue sticks too.
Thank you!
itsme2 is offline Find More Posts by itsme2
Old Oct 12, 2012, 10:18 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
Not sure exactly what you have there, but I use a dollar min glue gun from the local craft shop, and their dual temp glue sticks. It just barely melts the foam which actually helps it stick better. Also go easy on the glue... a little goes a long way, and adds a lot less weight.
FWIW, I mostly use FoamTac glue for foam now. It seems to weld the foam and forms a better more pliable joint than hot glue.
Try what you have on a scrap piece of foam.
rcav8r2 is offline Find More Posts by rcav8r2
For Sale Butane Hot Melt Glue Gun EBerris Aircraft - General - Miscellaneous (FS/W) 0 Jun 01, 2012 10:51 AM
Discussion Low-Temp Hot Melt Glue Contraindicated roo_ster Foamies (Scratchbuilt) 5 Apr 12, 2012 03:23 PM
Discussion Hot Melt Glue: Multi Temp verses Low Temp Sixter Foamies (Scratchbuilt) 8 Oct 01, 2008 08:05 AM
Alert Low Temp Hot Melt Glue and Car in Sun Don't Mix LittleJon Electric Plane Talk 1 Aug 26, 2005 02:58 PM
Hot Melt Low temp sticks ToddO Foamies (Kits) 12 Oct 18, 2004 02:03 PM
