Old Nov 10, 2014, 01:02 AM
Joined Feb 2009
Warning for those considering the MotionRC 90mm FA-18!
Thrust Vector off = No takeoff until you cut throttle = Multiple pieces of FA-18
Looks great however the thrust vectoring setup is a crap shoot. Had everything setup per the Chinese directions. However after the crash I realized that the thrust vector setup was not correct. Too late however... The thrust was directed slightly downward which forces the nose down.
​Here's what happened:
First time out this afternoon. Took off full bore, pull full up elevator and the nose stayed glued to the runway. Throttle full back, plane lifted up off the runway about 6 feet, reapplied throttle and FA-18 slammed into the runway. Now I know why the guy in the video took off with the thrust vectors turned on. Plane is now in garbage bag minus the fan and electronic parts.
​Thanks a lot for not sharing that tidbit of info about doing the first flight with thrust vectors turned on. Had the elevator thrust vectoring been turned on I could have trimmed it after takeoff and it would still be in one piece!
ftherrmann is offline Find More Posts by ftherrmann
Old Nov 10, 2014, 03:41 PM
Yeah, I can fly...
wyldkrd's Avatar
Mesa, Arizona
Joined Jun 2005
Thanks for the heads up on the F-18 TV. Although you are talking about an EDF let's keep the discussion here about the event itself.
wyldkrd is offline Find More Posts by wyldkrd
Old Nov 11, 2014, 11:21 AM
Field of Dreams Flyer
Mikemynameis's Avatar
San Pedro,Ca
Joined Sep 2004
Sounds like pilot error and not setting up the plane right. I have seen many of those jets fly with no problem
Mikemynameis is offline Find More Posts by Mikemynameis
Old Nov 11, 2014, 12:24 PM
BlazerB52's Avatar
Fenton,MO USA
Joined Aug 2005
Sounds like thrust angle set wrong. Example.
BlazerB52 is offline Find More Posts by BlazerB52
Old Nov 11, 2014, 12:43 PM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
So now do I cut and paste my previous replies since you deleted them? I did say that even though tis was your set up problem that it, and some other issues I brought up, should be posted here so people are aware of them.
Since you are just going to delete my posts I just say it's your set up problem and not a Motion or FreeWing issue.
Evan D is offline Find More Posts by Evan D
Old Nov 11, 2014, 01:02 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I would be inclined to think setup error as well. Mine flies great and i have the thrust vectoring permanently disabled on mine.
Freewing F/A18-E 90 mm Flight 2 (4 min 33 sec)
bill34207 is offline Find More Posts by bill34207
Latest blog entry: 12 o'clock high 2014
Old Nov 11, 2014, 01:30 PM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Bill, is that a V2 with flaps and the stock power set up? You said disabled, all of it or do you have yaw (rudder) still on?
Old Nov 11, 2014, 01:38 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
That is the V2 with flaps and just as it came out of the box Evan.
Edit: That might have been a little misleading as far as "as it came out of the box". I epoxied my TV nozzles into a fixed position and had to do some minor shipping damage repair. It is the stock power system though. Full mini build thread in my blog http://www.rcgroups.com/forums/showthread.php?t=2227469
Old Nov 11, 2014, 01:57 PM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Evan D, He has two of the same threads going-- your in this one-
http://www.rcgroups.com/forums/showthread.php?t=2282063
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Nov 11, 2014, 02:10 PM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
That is crazy whack....
Old Nov 11, 2014, 10:02 PM
United States, FL, Altamonte Springs
Joined Jun 2012
+1
Misaligned exit nozzle affects all EDFs. I built a Phase 3 EF16 that would pitch down with throttle due to the same issue. It was a handful to fly... no throttle = balloon into air.
I own the Freewing F18 from MotionRC and think it's a great flying jet. A pussycat.
voxel is offline Find More Posts by voxel
Old Nov 11, 2014, 10:08 PM
Scale Jet Driver
Rangerfan's Avatar
United States, TX, Grapevine
Joined Jul 2012
This is probably the easiest "scale" jet to fly IMHO. Its my go-to jet.
Rangerfan is offline Find More Posts by Rangerfan
Discussion exceed 90mm fa 18 or hobbly lobby Scott Seaman Foamy EDFs 11 Mar 27, 2014 01:25 PM
Wanted Non foam 90mm FA-18 buster232 Aircraft - Electric - Jets (FS/W) 0 Jun 20, 2013 02:38 PM
Sold Freewing FA-18 90mm - PRICE REDUCED! JGuilty13 Aircraft - Electric - Jets (FS/W) 8 Mar 12, 2012 09:41 AM
Wanted Considering trading Saito FA-65 Black Knight for FA-56 GEARHEAD_ENG Aircraft - Fuel - Engines and Accessories (FS/W) 0 Dec 29, 2010 03:34 PM
Discussion BH 90mm FA-18 i3dm Banana Hobby 0 Apr 19, 2009 03:53 PM
