Old Jul 06, 2013, 12:20 AM
metalwizard's Avatar
United States, UT, Hurricane
Joined Aug 2012
Help!
Gental Lady ARF CG problem
I started when I was about 12 flying gliders.. have not done it for YEARS.. (yeah I just turned 48)
so today I bought a Gentle Lady figuring that would be an EASY get back into glider ..plane.
got it all together just as the instructions tell you to build it.. and I am WAY tail heavy..
Now this is the ARF version so I KNOW I did not add to much weight to it.. almost no way you can..
I am using a LIFE 1100 mAH battery and it is as far forward as it can go (right against the back of the "nose cone"
I am using standard size servos.. and since I did not have a spektrum receiver I chose to throw in an OLD 72 Mhz futaba 7 channel receiver that I had from YEARS ago.. just to test her out..
so I mark the CG at 3 5/8 in back from the leading edge.. and to get it to balance.. I had to add almost 4 OZ of lead up beside the battery..
Now I can see maybe an OZ.. but 4 OZ seems like a TON.. has anyone flown/built one of these and did you have to add a ton of nose weight??
thanks in advance!
metalwizard is offline Find More Posts by metalwizard
Old Jul 06, 2013, 12:28 AM
more casual than stylish....
slopemeno's Avatar
Joined Jan 2003
Better to start there and try moving the CG back slowly later.
Gentle Ladys will carry a surprising amount of weight, and probably penetrate better with a little ballast. 4 ounces isn't that much.
edit- I'll bet you my kit built version is heavier than your arf. What's your all-up-weight?
slopemeno is online now Find More Posts by slopemeno
Old Jul 06, 2013, 12:30 AM
Joined Aug 2012
Awesome it just seemed like a lot.. so I figured I'd ask!
Thanks for the input.. I went with the 1100 Life because it was smaller... heck I should have got the 2200!! I could fly it for WEEKS on that LOL
Old Jul 06, 2013, 12:39 AM
slopemeno's Avatar
Joined Jan 2003
I have a 4-cell 1500 in mine made from an r/c car pack that probably weighs 12 ounces, and it's right on the CG. I have a huge chunk of lead in the nose to balance it too. Still will fly in some incredibly light air.
Old Jul 06, 2013, 01:02 AM
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
I use a 2200 3S Lipo in mine all the way foreward and it balances spot on.
It is the kit built and at minimum weight. Would have to take weight out of the tail to go less.
1320fastback is offline Find More Posts by 1320fastback
Old Jul 06, 2013, 01:47 AM
Be the duck. Whaaaa?
UberZogster's Avatar
United States, CA, Guerneville
Joined Mar 2012
I'm using a 2800mah NiMH and I still had to add weight. I think battery and weight is around 7-8oz. I did rebuild my tail feathers with heavy wood after my super light ones broke launching on a windy day. I can still work super light lift.
UberZogster is offline Find More Posts by UberZogster
Old Jul 06, 2013, 06:44 AM
Kurt Zimmerman ≡LSF 4461≡
kzimmerm's Avatar
Montrose, NY
Joined May 2003
What is your AUW? I seem to recall my GL was about 28 oz. built from a kit.
kzimmerm is offline Find More Posts by kzimmerm
Old Jul 06, 2013, 09:17 AM
Joined Aug 2012
Well from the answers It looks as if I am ok! I just wanted to be sure!
AUW?? I am sure that has something to do with final weight.. I dont have a scale that reads over 16 oz but right now the Fuse weights about 14 oz (no nose weight added) and the wing weighs 12 OZ so about 26- 27 OZ total. with nose weight I should be close to 30 oz
Old Jul 06, 2013, 10:35 AM
USA, CA, Oceanside
Joined Jul 2008
Mine weighs 25 ounces.
It is also the minimum weight stated in manual so that has to be for CG reasons I guess.
Old Jul 06, 2013, 11:04 PM
United States, MA, Waltham
Joined Dec 2001
30 ounces is ok for a glider this size. I don't know how much an 1100 mah LiFe pack weighs, but originally this must have been designed for a 4 oz. battery pack, 2 ounce receiver, and servos in the 1.5 to 2 oz. range.
If the c.g. you are using is from the instructions, it's probably conservative and you may be taking some of that nose weight out eventually.
It seems possible that some of the wood in the tail may be a bit heavy.
lincoln is offline Find More Posts by lincoln
Old Jul 07, 2013, 10:22 PM
Joined Jun 2012
please let us know where you where you finally ended up with the cg mine which i converted to electric flys best a little nose heavy balanced at the corner of the sheeting (if that makes sense) about 3/8 to 1/2 inch in front of recomemded cg
truckinhard088 is offline Find More Posts by truckinhard088
Old Jul 08, 2013, 01:34 PM
Joined Aug 2012
will do I have it at the factory recommended spot. and a touch nose heavy for the first flight.. should be saturday!
Old Jul 08, 2013, 04:35 PM
It's GoTime all the Time
gotime360's Avatar
United States, CA, Portola
Joined Nov 2011
Cut the nose off add a 28x36 1000KV outrunner with a 10x6 cam prop 30A esc and a 1300Mah 45C lipo and you have tons of fun.
I did this to my Sophisticated Lady. weight is 27oz
gotime360 is offline Find More Posts by gotime360
Old Jul 10, 2013, 12:03 PM
Joined Aug 2012
Looks like fun... how do you come in lighter than I did?? thats whats confusing me?? I mean I KNOW she will fly like this but it just seems she is awefully heavy!
Old Jul 13, 2013, 10:12 PM
Joined Aug 2012
Well got in her maiden this morning..
She does float like a dream!
Stupid hi start was killing me though... 3 times the "rope" snapped on me so never got a really good start on it.. Arrrgh..
but did get some other great flights in so I am happy!
I really do like the idea of powering her..
So what do you think... is this a good choice for motors??
http://www.headsuphobby.com/Firepowe...otor-E-645.htm
Alert Cg gentle lady arf ardvark Thermal 1 Apr 04, 2013 10:25 PM
For Sale original gental lady arf thermal chaser Aircraft - Sailplanes (FS/W) 0 Jul 31, 2011 07:09 AM
CG for Gental Lady and Electra SKYWLKR Electric Sailplanes 2 Jun 19, 2005 09:34 PM
Uning MotorCalc for Gental Lady larryw Power Systems 3 Mar 27, 2003 05:18 PM
Gental Lady conversion larryw Electric Sailplanes 2 Mar 20, 2003 12:59 PM
