Closed Thread
Old Oct 13, 2012, 01:33 PM
Jeffem62's Avatar
United States, TX, El Paso
Joined Apr 2012
Sony NEX 5N Frames Per Second Video???
Did the searching guys, but cant figure it out.
I have the Sony NEX 5N
A few questions.
Using the camera exclusively for AP work and it performs very well.
Getting some request for some video but its proving confusing and difficult for me. Im not a video guy.
1. Difference between 1080P and 1080i?? Camera gives an option or can leave at Auto.. For AV what is best?
2. Right now shooting in 1080p at 29 frames per second. Film quality is not great. Can I up the frames per second? If so How?
Thanks for the help
Jeffem62 is offline Find More Posts by Jeffem62
Old Oct 13, 2012, 02:43 PM
United States, TX, Thrall
Joined Feb 2010
You want to to set it to - 60p 28M (FS) in the movie mode it will show you the different settings the p stands for progressive and i is interlaced. 1080p will look better on large screens and on small screen the difference will be less between the two. Interlaced takes two columns odd and even and interlaces them together which mean you will not see all the frame all the time it mixes them as needed sometimes you cannot tell the difference between the two and other times you will. Hope this helps.
Michael64
Michael64 is offline Find More Posts by Michael64
Old Oct 13, 2012, 03:05 PM
Jeffem62's Avatar
Joined Apr 2012
For the life of me I can find what you are talking about on the camera.... Where is Movie Mode? Ive been through the entire camera, I must be missing it.
Under Image Size: Then to Movie you have these options:
File Format: Set to MP4
Record Settings: Set to 1140 x 1080 12m
Image Size: Set to 14m
Aspect Ratio: 16:9
Quality: FIne
Under Set Up:
HDMI: Set to 1080p
Cant find movie mode or how to change to 60p
Old Oct 13, 2012, 03:07 PM
Joined Feb 2010
You are in the MP4 you need to change that to AVCHD to get the high settings MP4 will not look good at all.
Michael64
Old Oct 13, 2012, 03:09 PM
Jeffem62's Avatar
Joined Apr 2012
Ahhh, ok went to AVCHD, now I have options.
60p 28m is what you recommend?
Old Oct 13, 2012, 03:10 PM
Jeffem62's Avatar
Joined Apr 2012
Ill experiment from here. Thanks a bunch, it was driving me nuts.
Old Oct 13, 2012, 03:11 PM
Joined Feb 2010
That should give you the best results. You may want to go to manual mode and manual focus as well if you the 16mm it will be soft I would suggest the 18-55 or a upgraded lens for better results.
Michael64
Old Oct 13, 2012, 03:12 PM
Joined Feb 2010
Glad to help and hope all goes well.
Michael64
Closed Thread
Build Log Askman's Shrimp Y6 Frame + Nex-5n Gimbal Build (prototype frame) Adidas4275 Multirotor Talk 96 Oct 30, 2012 06:46 AM
For Sale Sony NEX 5N w/h Sony 16mm lens kuau FPV Equipment (FS/W) 6 Jul 15, 2012 04:58 PM
Discussion Sony Alpha 35 or Sony Nex 5n for AP? Kr1st1an Aerial Photography 4 Nov 30, 2011 01:53 AM
Discussion Sony NEX 5N raw video footage SeismicCWave Multirotor Talk 5 Nov 17, 2011 01:10 AM
