My first flight with nova osd. IR calibration was successful and RTH worked even though it was dusk and even the street lights had come on. Also, there are a few bits of video with the rolling problem, but didn't last long.
![]() ![]() ![]() So where do I send this thing into to be fixed? Everything was working ok but had crappy video. Went back out to fly a bit ago after changing antenna on my vRx and nothing.....no led, no smoke, no video, nothing..... ApachePilot |
Joined Nov 2011
Hello all
I just purchased a nova osd after a friend bought one and has had great success. The problem with my osd seems that when I put it in RTH mode, it turns and seeks 'home' but in an unbelievable slow turn almost to the point where it doesn't seem to be working. If I am patient enough, it will eventually turn home but then make very very large circles over head. This is in stark contrast to my friends airplane that turns 'home' immediately with a moderate bank. He has the same setup as I do - servo throws etc. I have set up exponential to 20% but this should have no effect on the turning ration as the receiver is not controlling the airplane (the OSD is) - correct?. Any thoughts or suggestions? Is there a way to adjust the turning rate of the OSD? Everything else works fine - display/PA mode sensors gps etc. I would appreciate any suggestions. Thanks |
If your expo is set to twenty when you setup the servo movement the NOVA will record the movement of your Tx with mixes on. If you want a sharper bank, turn off expo and duel rates, maby even extend your EPA if it still isn't playing ball, recalibrate the nova and test with each step (to make sure you havn't gone too far :P)
CJ |
What plane are you using? |
| Thread Tools | |
| New Product OSD PRO from Eagle Tree (RTH, AHI, Waypoints, Variometer, Voice, now shipping) | billpa | Video Piloting (FPV/RPV) | 10555 | Today 04:17 PM |
| Discussion Cheap OSD with RTH? | raRaRa | Video Piloting (FPV/RPV) | 4 | Sep 15, 2011 09:20 AM |
| Discussion What's a good RTH system to use with FOXTECH CE OSD? | ajusaf | Video Piloting (FPV/RPV) | 13 | Jul 07, 2011 04:49 PM |
| Question Hexacopter with KKmulticopter, dragon OSD and RTH | evo585 | Multirotor Talk | 0 | Mar 27, 2011 09:46 PM |
| Discussion Need help with Eagle Tree OSD RTH! | Ellis108 | Video Piloting (FPV/RPV) | 2 | Nov 30, 2009 10:28 PM |
