Old Jun 18, 2013, 02:55 PM
MTheMadhatter's Avatar
Plymouth UK
Joined Jun 2008
Optima 6 , SPC and an Eflite ESC
I have a HABU and I want to set up the RX to read my Lipo voltage. I have done this with another model and had no issues, however
When I try this with the Eflite ESC it wont power the servos, or arm the throttle. It has a separate switch for arming the BEC, using this has no effect
With the SPC jump lead in place it all works as it should, but I get a continuous beeping from the TX , 3beeps in a row and then a pause then repeated.
The TX battery is fine, there is no alarm set for the RX voltage so I am confused
MTheMadhatter is online now Find More Posts by MTheMadhatter
Old Jun 19, 2013, 03:24 AM
Joined Aug 2002
Most likely cause is that you have not reset your Spectra module alarm:
. AFHSS - Warning Beeps Aurora 9 & Spectra 2.4Ghz Module - Interpret & Manage the Independent Alarms.
extract:
"Spectra Module Low Transceiver Battery warning provides triple beep = beep beep beep pause beep beep beep pause.
(When using SPC from EP power battery and module has been programmed with say a 3S battery 9.9v LBW setting
and a 2S even fully charged at 8.4v is to be used, alarm would be tripped.
Thus LBW setting for that model must also be changed via HPP-22)"
. Aurora 9 - Warning Alarms Battery types, Voltage Level Interpretation & Consumption
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS 2.4Ghz Module, Transceivers_Receivers & Telemetry
- FAQ, Setups & Tips {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Jun 19, 2013, 08:58 AM
Plymouth UK
Joined Jun 2008
Thanks, It was a new model memory and had not set any alarms up. However resetting them did the trick, well at least the beeping has stopped
I still cant get it to work with the SPC connected. With the SPC connected to my flight Lipo I have throttle control but none of the servo's will work. As I understand it the SPC does not power the servo`s and they should take there power from the BEC on the ESC,
Old Jun 19, 2013, 07:20 PM
Joined Aug 2002
However resetting them did the trick, well at least the beeping has stopped.
Please try swapping the ESC for another and into another model to ensure both it and the servo are working.
Unfortunately without model details of the ESC not provided, can not check manual for the ESC.
If it is set to and providing 5V, 5.5v or 6.0v then confirm wiring is as shown in schematic attached:
. Optima Transceiver (RX) - EP Models Use SPC Port for RX Power Supply (BEC only is unreliable) & correct Battery Telemetry.
. Optima Transceiver (RX) - SPC connection & Lead FAQ for EP & GP models - with schematics and Photos.
Much more information available under sub sections
"ESC & BEC - Setup to prevent majority of all RF Problems, Brownouts & Crashes"
"Glitches & Jitter in Receiver, Servo & ESC - Causes and Cures"
"Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ."
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan T.
Sold Hitec Optima 7; Optima 6(2); Minima 6 Hammer Aircraft - General - Radio Equipment (FS/W) 6 Jan 28, 2014 09:44 AM
Question Optima 6 - SPC Voltage available? RJSC Hitec/Multiplex USA 11 Jan 13, 2013 09:10 PM
Sold Trade Optima 6 for an Optima 9 Reegor Aircraft - General - Radio Equipment (FS/W) 2 Apr 20, 2011 05:27 AM
Sold Optima 9, Optima 7, Optima 6, Optima 6 Lite stickybeatz Aircraft - General - Radio Equipment (FS/W) 2 Apr 13, 2011 02:38 PM
Discussion SPC Power Connection on Optima 7 pete491 Hitec/Multiplex USA 0 Oct 25, 2010 06:45 PM
