Old Jun 04, 2008, 07:51 PM
Mikson is offline
Find More Posts by Mikson
Joined May 2008
Help!
Setup for BB V2
I bought a Bad Boy V2 for a couple of month ago, still not in the air ......
First I think to use a Saito 82, now I think to use any electric motor....
What would be the perfect setup if I go electric? Want to have as much power as the Saito 82 but in electric choice....
/ Mikael
Mikson is offline Find More Posts by Mikson
Old Jun 04, 2008, 08:26 PM
j.m. is offline
Find More Posts by j.m.
Don't worry about it!
j.m.'s Avatar
Raleigh NC
Joined May 2008
Check Hobby City. Not sure as to which specific motor to use, but they are sure to have what you need. (and for super cheap too.)
j.m. is offline Find More Posts by j.m.
Old Jun 04, 2008, 11:31 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
What is the weight range for the plane, preferably the max weight so that we can help you select a power system that will perform even better than the Saito.
Xpress.. is offline Find More Posts by Xpress..
Old Jun 05, 2008, 03:26 AM
Mikson is offline
Joined May 2008
The specs on the Bad Boy V2 is:
Wingspan-53"
Length-44,3"
Weight-4,5lbs
/ Mikael
Old Jun 05, 2008, 08:30 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
4-5 pounds eh? That means you will want a power system with about 800-900 watts of power, for unlimited vertical, and easy hovering. I don't know of any systems off the top of my head with that power, but you can browse around on Hobby City, and see what they have there.
Old Jun 05, 2008, 09:04 PM
blucor basher is offline
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
There's basically two ways to go using outrunners - a biggish 30mm system running at 650-800 watts (Hacker A30XL, Power32, etc.) or a 40mm outrunner running 800-1200W (Torque 4014-T570, MotrolFly 3625, Hacker A50-10S, etc.). 4S-5S 3200-3700mah is typical. A buddy who has tried both recommends the lighter 30mm system, I prefer the larger one. One's lighter, one's faster.
I have to disagree with Xpress's advice and recommend buying a name-brand motor if possible. I do, however, think that HC would be a good place to look for lower-priced lioply batteries.
The biggest issue we see with BadBoy conversions is the lack of a good battery-mounting location. Profiles are tough in the this regard. You can try it up high, or below the wing, and most people seem to agree that perfect location would be right in-between, or basically in the location we put the battery inside the fuse on non-profile airplanes.
Right now, I'm working on an Extreme Flight Chinn Yak55 conversion, I'm taking the time to fabricate a battery position inside the wing for this reason.
Good luck, it's a really fun plane.
blucor basher is offline Find More Posts by blucor basher
Old Jun 05, 2008, 09:46 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
I've heard good reviews about the Turnigy motors that Hobby City sells, but yeah, Hacker motors are definately a top choice if you want quality.
Old Jun 06, 2008, 04:49 AM
IMK is online now
IMK
Find More Posts by IMK
IMK
Australia, VIC, Melbourne
Joined Aug 2005
I recently completed an electric conversion of my BadBoy.
It was an absolute success.
My set-up is as follows:
Hyperion 4020-14 (574 kv) motor
Xoar 15x8
Hyperion 5S 3700 25c
Hyperion 80 amp Opto ESC
800mAh Eneloop NiMh Rx pack
Produces around 1100 watts and gives ballistic pull out from hovers.
Ready to fly weight is just over 5 lbs. It feels light in the air and does all 3D with authority. The large prop seems to help with torque rolls and rolling harriers.
I usually fly for around 8mins with about 2 more for reserve.
It was a straight forward conversion. Everything except the RX is mounted on the outside.
I'll try to get a few pictures if you're interested
IMK is online now Find More Posts by IMK
Old Jun 06, 2008, 04:54 AM
IMK is online now
IMK
IMK
Joined Aug 2005
With respect to the battery, I mounted it on the side using velcro and a strap (I first glued 1/64 ply to the fuz to provide a better surface for velcro adhesion).
To balance the battery I first figured which wing was heavier and mounted the RX, RX battery and ESC on this side. The 5S 3700 was then mounted on the other side. Believe it or not it balanced perfectly.
The balance in KE was pretty close. I mounted the battery high (above the centreline). The weight of the LG helps somewhat to offset this.
Old Jun 06, 2008, 04:58 AM
IMK is online now
IMK
IMK
Joined Aug 2005
This is my second 40 size profile electric conversion. Another tip about placement of gear to achieve the best balance is to tape everything on before deciding on the final location.
What I like about electric profiles is the ease of access to everything - its on the outside. Some may think this looks ugly, but hey, it flies great.
Old Jun 06, 2008, 09:06 AM
Mikson is offline
Joined May 2008
Thanx for good answers!
Xpress:
I have an Max BLO 2204 motor in my foamie and it seems to be exactly the same motor as the Turnigy, unfortunately it begins to sound very bad sometimes when I push it harder... Think I buy a more well-known motor, but thanx anyway.
blucor basher:
Is there any pictures of the conversion?
IMK:
WOW!! Yes I'm really interested of pictures! Videos is also welcome!!
What receiver/servos do you use?
/ Mikael
Old Jun 06, 2008, 09:32 AM
txfly is offline
Find More Posts by txfly
txfly's Avatar
frisco,tx
Joined Oct 2003
id go with a scorpion 4020-16 on 2 3s packs of 3300 in series. one one each side of the fuse. this will allow a big prop and the packs wont be so bulky
txfly is offline Find More Posts by txfly
Old Jun 06, 2008, 09:43 AM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Dang, this BadBoy profile sounds like a good one. I'll have to take a look at it.
Old Jun 06, 2008, 10:42 AM
txfly is offline
txfly's Avatar
frisco,tx
Joined Oct 2003
watch an electric video of the BB on eflightline.com
Old Jun 07, 2008, 05:13 AM
IMK is online now
IMK
IMK
Joined Aug 2005
I used JR DS 589 digital servos (5.2Kg torque) and an 8 channel Hitec RX. You could find a much lighter RX, but thats what I had on hand.
I'll see if I can get pictures next weekend if the weathers good.
Help! JR 8103 and setup for Shogun V2 btokarz72 Mini Helis 0 Aug 02, 2006 11:08 PM
Help! Jr 8103 setup for Shogun V2 btokarz72 Micro Helis 1 Jul 29, 2006 07:57 PM
Question Brushed Seperates Setup for Piccolo V2 FP WeatherB Micro Helis 9 Mar 07, 2006 06:34 AM
Setup for R3D V2? hmedina 3D Flying 0 Mar 08, 2005 06:28 PM
What's a Good Setup for Raptor .30 v2 (Electric Conversion) Lv2Fly Electric Heli Talk 24 Sep 24, 2003 11:58 AM
