Old Aug 27, 2005, 11:31 PM
Aerobat152A is offline
Find More Posts by Aerobat152A
Tryin not to be a hack!!
Aerobat152A's Avatar
SoCal
Joined May 2004
V-Bagging Setup.... Afternoon well spent!!
Target my Hero had peaked my interest while watching his techniques as well as his helping me a number of times and Vacuum bagging was something Ive wanted to get involved with. Robert aka RMD72377 had built a system that mine is a clone of....
http://www.rcgroups.com/forums/showthread.php?t=209707
This setup was real simple to make, as well as being pretty cheap to construct. It doesnt take up much space at all, and seems to work real well. Its been holding approx 15" vacuum for the last hour without any dropping of vacuum which means it probably wont be cycling too much in the process of actual bagging..... or my new gauge is busted
Thanks to Target and RMD72337 for all the info and inspirationable moments that helped build this system!!!! Also to my buddy Jim who owns the welder, and wired the Vac switch, relay, and the On-Off Toggle.
Aerobat152A is offline Find More Posts by Aerobat152A
Old Aug 27, 2005, 11:37 PM
Louied is offline
Find More Posts by Louied
ALL IN !
Louied's Avatar
Carlsbad, California, United States
Joined Feb 2004
O yeah Baby I am comeing over KILLER KEV
Louied is offline Find More Posts by Louied
Old Aug 28, 2005, 12:27 AM
SoCal
Joined May 2004
Anytime Louie
If anyones interested I can compile the list of parts that it took to put this together and Post It!!
Aside from a few parts from ACP which were the Vacuum Gauge, Vac Switch, and the Check Valve, the rest came from Lowe's including the tubing, and the On-Off Toggle Switch, and the Relay came from the Electronics Shop. Welding the bracket to hold the Fridge Pump is really just for convienience of keeping it together and it being self contained. It weighs about 30 lbs and is pretty solid and can be moved real easily.
Let me know if you want the list of parts.
Kevin
Old Aug 28, 2005, 12:45 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
One question-
Why aren't there any wings in bags for a working test???
Get busy!!!
Congrats, looks sweet.
Target
target is offline Find More Posts by target
Old Aug 28, 2005, 01:00 AM
nauga is offline
Find More Posts by nauga
Embrace the suck
nauga's Avatar
Joined Nov 2004
Originally Posted by Aerobat152A
This setup was real simple to make...
Dude, did you *really* use calipers to plumb a vacuum pump?
Nauga,
who says, "Tape and rope's our only hope"
nauga is offline Find More Posts by nauga
Old Aug 28, 2005, 01:03 AM
SoCal
Joined May 2004
Originally Posted by target
One question-
Get busy!!!
Target
Thanks Target My Hero
All I need to get is a few things from ACP, and Im Bagging Ill order the stuff on Monday!!! If your still up... gimme a call and help me put that list together or Ill call you tommorrow. Thanks for the info that helped put this thing together. Between this Bagging setup & the Feather Cut System I just bought, it opens the doors to some nice projects I can do now without having to bug you everytime I need cores or want something bagged!!
Thanks again Target..... Your a good Egg!!!
Kevin
Nauga,
LOL.... Nauga..... makes some measurements quicker and easier than pencils and rulers sometimes. Takin ID's, OD's........ it works.
Old Aug 28, 2005, 01:10 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Nauga,
"Precision tool, precision build."
Old Aug 28, 2005, 01:45 AM
SoCal
Joined May 2004
I can only hope
Old Aug 28, 2005, 03:03 AM
IMoonBark is offline
Find More Posts by IMoonBark
Something MUST FLY!
IMoonBark's Avatar
OC, there is no "The OC"
Joined Jun 2004
Very cool, looks like something else that is required!
Very nice setup, I look forward to seeing some wings come through your shop. Please keep us up to date!
Heyas "T"... I wanna come see your process if you don't mind "spies".
What kind of materials do I need for my "Konan" Cheetah wings?
IMoonBark is offline Find More Posts by IMoonBark
Old Aug 28, 2005, 09:32 AM
nauga is offline
Embrace the suck
nauga's Avatar
Joined Nov 2004
Keep in mind that you caught grief from a guy who once had to make 5 trips to the hardware store to install a single toilet.
Your setup looks great. Can't wait to see what comes out of it.
Nauga,
who was famous in the plumbing department
Old Aug 28, 2005, 10:25 AM
Battleseed is offline
Find More Posts by Battleseed
Joined Jul 2005
Anytime Louie
Kevin
Can you post a list of parts or PM it to me. Thanks much.
Battleseed is offline Find More Posts by Battleseed
Old Aug 28, 2005, 10:41 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
That's some CRAP!!!
T
Old Aug 28, 2005, 10:52 AM
Kimble_Schmitz is offline
Find More Posts by Kimble_Schmitz
Ain't Dutch? Ain't Mutch!
Kimble_Schmitz's Avatar
Southampton, UK
Joined Oct 2001
Wicked!
I was at the local city dump the other day and picket up an old (almost new) fridge pump. The pump appears to be working fine. Some day I will convert it into a vacume machine. A good friend of mine did this to, works a treat!
Only think is, I have no plans for the moment of using it. No time.
Hope you do use it!
Jos.
Kimble_Schmitz is offline Find More Posts by Kimble_Schmitz
Old Aug 28, 2005, 03:29 PM
SoCal
Joined May 2004
Will do Battleseed...... Ill post em here at some, and Ill PM them to you. Thanks for asking.
Kevin
Old Aug 28, 2005, 03:45 PM
slopemeno is online now
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
I'd like to see a build thread where you just do the wings from begining to end. I have been thinking about starting a vac bagging setup, and our refrigeration guy at work is getting me a pump.
slopemeno is online now Find More Posts by slopemeno
Question Eclipse TX with V-tail, setup? 10Thumbs Hand Launch 9 Sep 17, 2002 10:35 AM
Tiny V-mix setup jonic Parkflyers 1 May 30, 2002 02:33 PM
Question Tiny V tail setup d12bn Parkflyers 3 Feb 10, 2002 11:11 AM
ELECTRICUB- Will this setup work well? JIMJAM Sport Planes 4 Feb 04, 2002 08:46 PM
Smart V-tail setup? Hammer Electric Sailplanes 2 Oct 30, 2001 10:14 PM
