Old Jun 15, 2005, 05:54 PM
Biper/Piper is offline
Find More Posts by Biper/Piper
United States, IN, Plymouth
Joined Jul 2004
??Sealing Monocote trim ???
Does anyone have a good way to fuelproof & seal a Monocote trim scheme other than glueing the edges?? Can you use Polyurethane clearcoat over Monocote or does that make a mess of things?
All suggestions appreciated.
Biper/Piper is offline Find More Posts by Biper/Piper
Old Jun 15, 2005, 06:32 PM
mode1 is offline
Find More Posts by mode1
mode1's Avatar
Southwest Missouri
Joined Oct 2002
I have used water based P.U. on the edges of Monocote and other plastics with good results. After shrinking and sealing the completed covering very well, I clean the surface and apply the P.U. with a small paint brush or cotton swab. Edges only except for very small areas that get covered complety for simplicity. Two light coats. Apply thin to avoid runs. Milky when applied, clear when dry.
mode1 is offline Find More Posts by mode1
Old Jun 15, 2005, 10:03 PM
Joined Jul 2004
Thanks. I didn't know if it would adhere well or just peel off taking stripes with it. I was thinking of the spray, but it makes more sense your way with the liquid form.
Monocote Trim nr5a Electric Plane Talk 4 Apr 05, 2005 02:05 PM
WTB - Sealing Iron/Trim tool slo_dave Aircraft - Electric - Airplanes (FS/W) 2 Apr 04, 2005 07:32 PM
