Old Oct 23, 2004, 01:11 PM
Bob Peck
Bob Peck
Guest
n/a Posts
Pike V-tail Antenna
Pike Owner's,
What is your antenna solution for the v-tail? I have seen the Samba
website but would like to know of your practical experience. This is my
second Pike. My first is a light model with the antenna ran through the wing
D connector out into the wing behind the spar and carbon D-tube leading
edge. It ground checks "OK" and I can fly it at the edge of my sight with no
problems.(72mHz)
My new Pike (50mHz) has a carbon center section and I won't use the
above setup. I built another with a carbon c-section Pike and doubled the
antenna length to .5 wave and dangled it out the back of the fuse. Reception
is good, but it looks like hell and it is bothersome during launch. Any
suggestions? BTW radio equipment is Airtronics TX/RX.
Bob Peck
Tulsa......BOOMER SOONER
RCSE-List facilities provided by Model Airplane News. Send "subscribe" and "unsubscribe" requests to soaring-request@airage.com. Please note that subscribe and unsubscribe messages must be sent in text only format with MIME turned off.
Old Oct 23, 2004, 05:11 PM
Ron Russell
Ron Russell
Guest
n/a Posts
Re: Pike V-tail Antenna
In message <000501c4b91a$2fc08190$f2fb6144@bobu9m95fe3das>, Bob Peck
<xcfrmok@cox.net> writes
>Pike Owner's,
>problems.(72mHz)
Hi there, I have a few Pikes and have tried all the options on the web
site. I prefer the split V extension where aerial wire is fed up both
tailplane halves and only an inch or so is left dangling in the breeze.
With the cross tail I extend and run the aerial up the rudder trailing
edge.
With the V Extreme the wire is extended and only goes up one tailplane
half, no reason except to try it. All methods work well, no glitches or
unexpected flap/aileron movements that can be traced to the radio.
I unfortunately have to admit that the unqualified wobbles are all pilot
induced.
> Bob Peck
>turned off.
Ron Russell
Pike v-tail 4 sale owdear Aircraft - Sailplanes (FS/W) 13 Mar 17, 2004 02:03 PM
