Old Jan 30, 2016, 06:55 PM
splais is offline
Find More Posts by splais
Yuma, AZ
Joined Oct 2003
Freewing 90mm 12 Blade Metal EDF 6S Power System with 4068-1680kV Brushless HET Inrun
has anyone seen any numbers on this combo? How many amps and watts its operating on? thanks
for those that don't know, it is an upgrade for several of the Freewing 90mm EDF's.
splais is offline Find More Posts by splais
Old Jan 30, 2016, 11:32 PM
Alpha10 is online now
Find More Posts by Alpha10
Alpha10's Avatar
United States, IL, Chicago
Joined Aug 2011
It pulls about 118 amps on 6s IME. It's nice... Just a little to amp hungry for me. I'd rather run a hot JF90/HET 2085kv and actually get some speed for an amp draw that high.
Alpha10 is online now Find More Posts by Alpha10
Old Jan 31, 2016, 07:46 AM
splais is offline
Yuma, AZ
Joined Oct 2003
Alpha10, you are saying a lot more amp draw with very little extra speed on that FW fan ? You didn't mention watts on that FW setup. Picking the unit is my problem. The JF90/HET2085 is $250; the FW90/HET1680 is $80 cheaper. What about some numbers on that JF/2085 setup. How to pick. Need some comments from someone who maybe had both.
Old Jan 31, 2016, 07:59 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Cheaper is not always the way to go! I prefer quantity over cheap ..
For my FlyFly F-86, it will have a JF90/Het 700-68-1500Kv on 8s
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jan 31, 2016, 08:12 AM
splais is offline
Yuma, AZ
Joined Oct 2003
A companion question to all this is: for a 6s setup on a JF90 fan, how do I pick the right motor? Freewing is using a 1680kv HET and I know others are using the 2085kv HET?
Old Jan 31, 2016, 09:44 AM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
Go here and look at the 6S performance table. http://effluxrc.com/Jetfan-90mm-EDF-...g-JF-90EDF.htm
The 1680 kv will be slightly better than stock, 1865 quite a lot better, 2085 is quite hot.
FWIW, 1680 is very usable on 8S for future projects. A Mini-Avanti for instance...
Chris True is offline Find More Posts by Chris True
Old Jan 31, 2016, 09:51 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
It is too bad FW or CS hasn't made a 10 blade fan in 90mm size to help with efficiency (like the CS 70mm version).
4stripes is offline Find More Posts by 4stripes
Old Jan 31, 2016, 12:02 PM
Alpha10's Avatar
Joined Aug 2011
No no... He's talking about the 1680 in a FW12 vs the JF90.
The Freewing inrunner version is considerably better than the stock 1550 outrunner, no doubt... The thrust is very strong with it and the speed is decent.
The JF is just more efficient in terms of amp to power ratio.
It really depends on how heavy the plane is, if you want sound more than speed, and what size packs/flight time you want.
Old Jan 31, 2016, 12:05 PM
Alpha10's Avatar
Joined Aug 2011
Agreed... Although I DO use the HSD 10 and Taft 11 blade units in some of my planes with great success
Old Jan 31, 2016, 12:52 PM
splais is offline
Yuma, AZ
Joined Oct 2003
I just want this plane to have decent speed flying at less than WOT. Whether the FMS90/HET1680 combo will do that, or I need to go JetFan still trying to work out. I had to have 1.75 oz of lead in the tail to get the CG at 185mm using the Zippy Compact battery. Unfortunitely my mornings testing was completely ruined. I now have a new problem - the nose gear works fine on the ground; airborne it will not go up. Tried three times, so now I have to tear into that little problem.
Old Jan 31, 2016, 02:21 PM
Alpha10's Avatar
Joined Aug 2011
What plane are you talking about? The nice thing about the FW12 1680kv is that it's heavy and you won't need to put any dead weight in the tail anymore.
The JF combo is much lighter and sounds like it wouldn't be ideal for the airframe if you're already adding tail weight.
Old Jan 31, 2016, 03:32 PM
splais is offline
Yuma, AZ
Joined Oct 2003
The plane is version 1 of the Sebart 90mm G-91. It has a 90mm Freewing 6-blade fan. no idea what the kv is, it could be 1750 but not sure.
Old Jan 31, 2016, 07:57 PM
ex-racr is offline
Find More Posts by ex-racr
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
I've followed the G-91 thread and I saw this. I suggest you invest in this:
From XtremeRC
http://www.extremerc.com.au/estore/i...oducts_id=1278
or this from EffluxRC:
http://www.effluxrc.com/Assemble-and...ance-ASBAL.htm
Both can provide what is essentially the same combo-except Xtreme uses an alloy housing.
Just my .02
ex-racr is offline Find More Posts by ex-racr
Sold Freewing Ready2Fly 90mm 12 Blade EDF 6s INRUNNER Power System howieal Aircraft - Electric - Jets (FS/W) 2 Dec 16, 2015 11:44 PM
Sold Freewing 90mm 12 blade (blue) w/het 1680kv / 130a esc / 8a bec 420flyboy Aircraft - Electric - Jets (FS/W) 0 Apr 24, 2015 09:28 PM
Wanted Freewing 90mm 12 Blade Metal EDF Power System HP - Red DamonH Aircraft - Electric - Jets (FS/W) 0 Mar 19, 2015 02:50 PM
Discussion Freewing 90mm 12 Blade Metal EDF Power System HP Evan D Foamy EDFs 7 Nov 01, 2014 08:21 AM
Sold Freewing 90mm 12 Blade Metal EDF Power System with 130A upgraded ESC taildragger21 Aircraft - Electric - Jets (FS/W) 3 Oct 03, 2014 07:33 PM
