Old Apr 26, 2015, 06:22 PM
bpbat21 is offline
Find More Posts by bpbat21
bpbat21
bpbat21's Avatar
United States, AZ, Tucson
Joined Mar 2014
.02 cents worth on your flight controller
Looking for a reliable flight controller. Was thinking about the A2...lots of money and no "follow me" feature. Can you even enter waypoints into it?
Just looking for some feed back from you guys...pros and cons ect...
I ve been using the Naza V2 and have been somewhat pleased. I m building a second and looking for a little more performance.
Thanks fellas
Ben
bpbat21 is offline Find More Posts by bpbat21
Old Apr 26, 2015, 06:41 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
See next post.
RC Man is offline Find More Posts by RC Man
Old Apr 26, 2015, 06:46 PM
RC Man is offline
United States
Joined Feb 2001
I recommend Pixhawk
I have been using autopilots/flight controllers for quite a few years and have tried most all of them. These days I have gone to Pixhawk autopilots on all my aircraft. For my long range aircraft I use the dual sensors for better accuracy and reliability. The Pixhawk support redundant GPS, magnetometers, gyros, and accelerometers. Dual gyros and accelerometers are built in and the others are external options.
The best thing about Pixhawk is it's open source hardware and firmware so you have more than manufacture to choose from. I have found some of the real cheap versions to be of lower quality. The ones from 3drobotics.com are the most expensive but they are the best. Unlike the low cost Chinese clones 3DR products have a warranty and excellent customer service.
Old Apr 26, 2015, 06:52 PM
bpbat21 is offline
bpbat21
bpbat21's Avatar
Joined Mar 2014
Thanks RC.
I m looking to get into some longer range stuff. That seems to be the only thing to do out here in the desert.
Old Apr 26, 2015, 09:29 PM
boogyman is offline
Find More Posts by boogyman
United States, CA, Folsom
Joined Jun 2006
I like the eagle tree vector. It doesn't have "follow me" mode or autonomous mission flight like the pixhawk, but the configuration software is easy to use and it's about as plug-n-play as it gets for setting it up. It does support waypoints (just not autonomous). It also has return to home, loiter and some other nice features.
boogyman is offline Find More Posts by boogyman
Old Apr 27, 2015, 06:09 PM
v2rocketeer is offline
Find More Posts by v2rocketeer
v2rocketeer's Avatar
Australia, NSW, Ingleburn
Joined Mar 2013
Thanks fellas
Ben
Hi Ben
Some more info is really needed from you to answer this.
I assume some form a multirotor is your next build. If you're looking for all out performance as that is all you stated above I would look at the Naze32 board. A lot of the miniquad racers are using that one, myself included.
Chris
v2rocketeer is offline Find More Posts by v2rocketeer
Old Apr 27, 2015, 06:44 PM
RC Man is offline
United States
Joined Feb 2001
Does the ET offer redundant sensors? Thatís what you want for long missions.
Old Apr 27, 2015, 07:46 PM
boogyman is offline
Joined Jun 2006
I don't believe it has redundant sensors. I didn't factor that in - didn't think it was one of the OP's requirements.
Old Apr 28, 2015, 02:03 PM
bpbat21 is offline
bpbat21
bpbat21's Avatar
Joined Mar 2014
Reliable is a must...least likely to fly away. My next build is a quad...I ve got most of the pieces...just looking to see what FC would be best. I have a Zenmuse gimbal, that is why I was leaning toward the A2. I will have 1.3gh tx video on a dragon link radio. Thanks for all your inputs. I m still up in the air.
Suggestion My two cents on the 50% on-topic rule madsci_guy Site Suggestions / Complaints 1 Dec 05, 2013 04:56 PM
Discussion .02 Cents, Comments, Suggestions, and Criticism... Please help coldwaterak The Builders Workshop 18 Dec 15, 2008 01:50 AM
Question your two cents on some table saw Le petit normand Dock Talk 31 Dec 11, 2008 07:35 PM
Discussion We just try to make you feel every cents spend on GWS is worth to it again and again! GWS4CEO Taiwan 1 Sep 18, 2008 07:18 PM
Discussion My .02 cents Lunns Australia 1 Feb 07, 2006 10:45 PM
