Old Mar 21, 2014, 07:08 AM
iflyrc4333 is offline
Find More Posts by iflyrc4333
iflyrc4333's Avatar
USA, NY, Tyrone
Joined Sep 2007
Flying off Grass ?
Some of us are not so lucky as to have a paved strip.. Does anyone have any experiance our carnal knowledge about EDF's flying off Grass Strips? I want to get the Taft 90mm Viper.. But worry about being able to fly it ones I get it ?
Thanks for your thoughts !!
iflyrc4333 is offline Find More Posts by iflyrc4333
Old Mar 21, 2014, 09:24 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
It seems most planes have enought power, but they lack in wheeel size.
On our grass field, my rule of thumb is, no less then 2.25 ", and if possible 2.5". Total AUW also figures into it. I have read many threads where the owner modified the wheel wells to accept larger wheels just for grass.
How smooth your field is also plays into it. Grass length??
If it's as flat and smooth as a putting green I wouldn't worry!
But if you have enought power, 2" might work.
In this post is Tumblers xXx, If I recall correctly, he had used 2.25" wheels. But his power is an XtremeRC 127mm fan.
http://www.rcgroups.com/forums/showp...postcount=1301 .. video in post.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Mar 21, 2014, 03:25 PM
Ken Lapointe is online now
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
All my EDF's fly off grass
As cooler said , wheel size and grass height are 2 top considerations.
Its really amazing what grass height does to the takeoff run. I had larger planes that would take the whole runway with normal height grass. Our club starting cutting it shorter and my planes would take less than 1/2 the runway. The difference was huge.
You probably want a plane with flaps, so you can get that little extra lift on takeoff.
I also find that I need to have more power in my planes then someone with the same plane flying off pavement, so more cells.
Ken Lapointe is online now Find More Posts by Ken Lapointe
Old Mar 21, 2014, 05:22 PM
E-speed buff is offline
Find More Posts by E-speed buff
186mph Funjet Ultra
E-speed buff's Avatar
nieuw vennep, the netherlands
Joined Feb 2010
I have flown the E-Flite Super Airliner from grass, with the original wheels!
At first it would only taxi around, but after I set the ailerons ~30dgr down as flapperon, it would take off without a problem.
René
E-speed buff is offline Find More Posts by E-speed buff
Old Mar 21, 2014, 09:51 PM
tom bacsanyi is offline
Find More Posts by tom bacsanyi
tom bacsanyi's Avatar
farmington hills mi.
Joined Sep 2006
Have the mains near the cg and a lot of elevator so you can rotate. Be quick to get off the elevator soon as it rotates. The video is of a Falcon 120 that weighs 19 lbs. and has about a one to one thrust to weight ratio. It also has the stabilizer "inverted" from the stock position. The stabilizer provides a down force so if a cambered stabilizer is used, it should have the curved side down. I think the wheels are 2.25 dia. and you can see they are buried in the grass. I also used full flaps.
Untitled (0 min 8 sec)
tom bacsanyi is offline Find More Posts by tom bacsanyi
Old Mar 22, 2014, 11:30 AM
iflyrc4333's Avatar
USA, NY, Tyrone
Joined Sep 2007
Hey Guys thanks for all the feed back... feeling a little more comfortable about it now !
Thanks again
Old Mar 22, 2014, 11:57 AM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
This video is of a ready2fly DH-112 Venom 90mm foamy powered buy a turbine flying from grass pretty impressive! The Venom has 2-1/2" main wheels and 2-1/4" nose I have the Vemon kit I,m working on now will fly from grass as well.
Ready2fly Venom Lambert Kolibri T25 (8 min 35 sec)
BadLemon is offline Find More Posts by BadLemon
Question Anyone flying RC ground effect planes over grass? RC Aerobat Electric Plane Talk 7 Dec 15, 2013 08:24 AM
Discussion YAK 54F. Flying off of grass. Landing gear issues?? markerbeacon Foamies (Kits) 1 Feb 21, 2007 06:22 AM
Yippee! Flying Off Wet Grass rckamikaze Waterplanes 4 Apr 29, 2004 04:24 PM
Changes for flying off grass? Pat Randall Sport Planes 7 Nov 09, 2001 08:05 AM
