Old Jan 18, 2013, 11:33 AM
Brian Koester is offline
Find More Posts by Brian Koester
Blue Stick's Dad
Brian Koester's Avatar
Westchester, Ca
Joined May 2003
Help picking gear for Pica FW 190
I have a Pica FW 190 on my building board and I'm at the point in the wing build where I need to install the retracts. I've never bought retracts before so my knowledge is thin. I know I want mechanical or electric retracts and not air. The plane should have 74 degree gear in order to look right. The plane comes in at around 9-10 lbs in looking at other builders final weight. The wingspan is 63.5" (1/5 scale?). The struts on the plan are about 6" long. The total space allowed in the wing for the retracts is 11.5".
The plans don't mention any specs for what retracts to use. I'd like a more scale set so I'm leaning away from wire struts. What I want to know is the model number for a set of retracts that will work with this plane. Anyone know?
Brian Koester is offline Find More Posts by Brian Koester
Old Jan 18, 2013, 12:43 PM
scalercer is offline
Find More Posts by scalercer
Joined Nov 2012
I'd go with Sierra Precision or Robart.
scalercer is offline Find More Posts by scalercer
Old Jan 18, 2013, 02:01 PM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
Shinden Machine makes retracts w/struts with the correct angle for the FW-190
http://shindinmachine.com/FW190/FW190.html
Looks like you'll have to contact them for a price.
Spring Air also makes a 74* set that is bored for a strut and is very reasonably priced, part #709
http://retracts.com/Retrax_700.htm
...and you could get just the struts from Shindin.
I have the 65" Platt -D9 and will probably be using the Shindin units when I rework the wing for retracts.
Hemikiller is offline Find More Posts by Hemikiller
Old Jan 18, 2013, 05:14 PM
SrTelemaster is online now
Find More Posts by SrTelemaster
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
At 63.5" WS, the scale would be about 1/6.66, call it 1/7.
SrTelemaster is online now Find More Posts by SrTelemaster
Old Jan 18, 2013, 05:52 PM
Ken Lapointe is online now
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
I ordered the Spring Air retracts frm Spring Air for my PICA kit in October, I'm still waiting for them
Ken Lapointe is online now Find More Posts by Ken Lapointe
Old Jan 18, 2013, 10:10 PM
Blue Stick's Dad
Westchester, Ca
Joined May 2003
Which Sierra or Robart? That's my problem. I can't tell which gear from either of them would be best for my application.
BTW, I'm avoiding Air systems for two reasons. First, it's the system that's the most prone to failure with all the places in the system that could fail. And secondly, mine is an electric conversion and I want the space for my batteries where the air cartridge would go.
Old Jan 19, 2013, 10:15 AM
TomCrump is online now
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
You are looking for retracts for an out of production model designed when air systems were prevalent. In my opinion, they are still your best option.
Any leaks are usually the product of the model builder, not the manufacturer. Mine have proven to be trouble free.
These model tend to build tail heavy, so your batteries will most likey need to be placed in the fuel tank compartment.
With that being said, if you do decide to go with an air system, look for one that fits the more current, although also out of production, Top Flite 190 D. They were of similar size, so the retracts should be easily adapted to the Pica airframe.
TomCrump is online now Find More Posts by TomCrump
Old Jan 20, 2013, 07:42 AM
Hemikiller's Avatar
Joined Dec 2005
Shindin will sell his retacts minus the air cylinders for those wanting to do an electric conversion.
Old Jan 20, 2013, 03:25 PM
Blue Stick's Dad
Westchester, Ca
Joined May 2003
I managed to find my way back to the Lado retracts website. Last time I was there, there was a backlog of orders and not much for me. This time they seem to be up to date on orders. And I found some retracts that will fit perfectly all for $382 shipped. I got electric RS333 retracts at 74 degrees and the exact length struts I wanted. Plus I got some scale wheels and gear door brackets. Hopefully, I won't wait forever to get them.
Sold NIB Rare Pica FW-190 for $225.00 pdansalvish Aircraft - Fuel - Airplanes (FS/W) 2 Dec 21, 2011 07:33 AM
Wanted Canopy for Pica FW 190 barkleyb Aircraft - Fuel - Airplanes (FS/W) 5 Jul 16, 2009 03:38 AM
Wanted canopy for Pica (Platt) FW 190 barkleyb Aircraft - General - Miscellaneous (FS/W) 0 Jul 13, 2009 06:01 PM
Glow to Electric Setup for a Pica FW-190 russcher Scale Kit/Scratch Built 2 Jul 09, 2001 11:10 AM
PICA FW-190 First Flight ArgueRed Scale Kit/Scratch Built 13 May 21, 2001 09:41 PM
