Old Dec 08, 2012, 05:33 AM
Berkie is offline
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia, VIC, Melbourne
Joined Feb 2007
Foamies that won't recover from steep dives
Hi All
It has happened again! No recovery from a steep dive.
I have had this happen once in an EZ* and 3 times now in EZ glider Pro
This time I wanted to see how she would stabilise fro a nose down attitude so I let go of the sticks, but the dive steepened quickly, I applied full up, but no result.
She went in vertical
After the crash I found the ESC & motor to be very hot which was probably due to a full throttle climb. Even though the ESC may have failed control should have been OK because it has a separate Rx battery, although I did try throttle just before she hit and I am not sure, but I don't think there was a response. All 4 servos were still working after the crash (didn't test motor)
A thing I thought strange though, was as I got close to the wreck (say 10 metres) the FrSky Tx beeped telling me there is loss of signal. Funny, because with the aircraft on the ground it should have beeped 50 metres away then stopped when I got to 10 metres.
Is this crash due to the higher load in a dive that the control system in these foamies just won't cut it? E.g. the control wire is too long and cannot exert enough force?
I have not heard of EZGPs needing the elevator servo mounted in the tail, but it looks like that's what I will have to do
Berkie is offline Find More Posts by Berkie
Old Dec 09, 2012, 09:55 AM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Did you reduce the throttle in the dive? I can see blow back on the elevator in a full power dive.
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: A letter from my Senator.....
Old Dec 09, 2012, 11:39 PM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Ken
Yes Ken the power was off
Kev
Old Dec 10, 2012, 01:01 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
As Ken mentioned, blow back.
With the usual, 'push for up' push rod set up, i.e. elevator horn on the underside, then a check with a little finger pressure on the elevator while operating the servo is worthwhile.
If the push rod is flexing or bending, then something need changing before any high speed flying.
eflightray is online now Find More Posts by eflightray
Old Dec 11, 2012, 04:57 AM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Thanks eflight
I'm going for elevator servo at the tail now for all long fuz planes.
I think that is the best insurance
Kev
Old Dec 11, 2012, 07:12 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Originally Posted by Berkie View Post
Thanks eflight
Kev
Yes, but.
Watch the CG. Adding even 9 grams towards the tail can mean quite a chunk of lead at the front to compensate. It's the lever problem with shortish noses.
9 grams 12" from the CG, needs 36 grams 3" the other side to maintain the balance.
Old Dec 11, 2012, 06:41 PM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
Yes, but.
Thanks eflight.
I am always careful on CG which I would have checked but, I wasn't taking into account the weight penalty. So now that you have given me the heads up I think I'll look for a lighter servo than the 12g I have in there now.
Lighter will mean less torque, but it should not need a lot in that position
Kev
Old Dec 11, 2012, 06:54 PM
Berkie is offline
Great Southern Land
Berkie's Avatar
Joined Feb 2007
What do you think guys- will this fit the bill?
http://www.hobbyking.com/hobbyking/s...2kg_10sec.html
Kev
Discussion Mask that won't lift paint from foam! CF105 Painting and Finishing Tips 12 Oct 02, 2012 01:25 PM
Help! Looking for a hot rod outrunner That won't melt down in 60 seconds masnoodles Electric Plane Talk 1 Jul 16, 2012 08:48 AM
Discussion New DX6i TX won't bind with AR6115e that came in box cunningbaldrick Power Systems 1 Jul 03, 2012 03:47 AM
Discussion How to design wings that won't stall in a thermal turn? GreenAce92_v2 Sailplane Talk 28 Mar 28, 2012 09:01 PM
Discussion My latest Foamy (it won't fly) larryross Car Talk 21 Feb 26, 2012 09:28 AM
