Old Nov 19, 2012, 11:44 AM
Ken Gerrard is offline
Find More Posts by Ken Gerrard
Retired aircraft maintenance
Ken Gerrard's Avatar
United Kingdom, England, Wiltshire
Joined Oct 2009
Recommend an airframe for this set up ?
Hi fellas, Can any of you EDF experts recommend a scale airframe to suit an ex Squall EP set up with 64mm five blade fan, 40amp ESC and on 11.i v lipo system. It was in the lower powered Squall, and really shifted till the foam bits turned to powder after one interface too many.
Seems a shame to bin a good system that just needs a plane to go into, but up to now I haven't seen anything as an airframe only that ticks all the boxes.
Be obliged for any suggestions guys, especially one that's already been done and is good, scalish and fun.
Ken Gerrard is offline Find More Posts by Ken Gerrard
Old Nov 19, 2012, 01:44 PM
Double E is offline
Find More Posts by Double E
Double E's Avatar
Atlanta, GA
Joined Mar 2009
There are a lot of 64mm EDF jet options on the market. Many of them would come with their own power system so you may need to look for a foam only kit. Here is a link to some 64mm foam kits from NitroPlanes. I assume Banana Hobby and Hobby King would also have a selection to choose from.
http://www.nitroplanes.com/exrcedfki.html
Double E is offline Find More Posts by Double E
Old Nov 19, 2012, 02:20 PM
stingeragents is offline
Find More Posts by stingeragents
Joined Jan 2011
You could always scratch build one. Fairly easy to convert pusher jet plans if your so inclined,
stingeragents is offline Find More Posts by stingeragents
Old Nov 19, 2012, 05:28 PM
clinth01 is offline
Find More Posts by clinth01
Vertical Arrival Specialist
clinth01's Avatar
Townsville, Australia
Joined Sep 2009
If 'scale' is not a deal-breaker, the HK Jetiger would be a good airframe. Cheap enough that removing the PNP power system and replacing it with yours is possible. Always good to have a back-up power train on hand Easy hand launch and heaps of power.
I replaced mine with a 4S system, and it is quite quick for a small airframe.
clinth01 is offline Find More Posts by clinth01
Old Nov 19, 2012, 07:48 PM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
phase 3 F-16 would be perfect for your setup. Repainted, they look pretty scale too.
Cheers
4stripes is online now Find More Posts by 4stripes
Old Nov 20, 2012, 04:26 PM
Joined Oct 2009
Cheers everyone, seems as if the impeller from the Squall is actually 68mm not 64 as Phase 3 state, so widens the field somewhat. Still looking for a scale type airframe though. Shame to chuck a perfectly good set up for lack of a wee bit of plastic huh.
Yep, that Phase 3 F5E would be just fine, but try getting an airframe only pack in the UK ...Humph !
Discussion Anyone have an old Dynamax Shroud For set up? Ron101 Electric Ducted Fan Jet Talk 1 Apr 26, 2012 07:15 PM
Help! need recommendations for brushless mini-mag set up Hot_Wheels Beginner Training Area (Aircraft-Electric) 5 Mar 10, 2012 05:44 AM
Discussion Will this slightly different mixer set up for an Octo work? jessestack Multirotor Talk 1 Dec 07, 2011 11:45 AM
Discussion Recommend me an airframe for this gear jackosmeister High Performance 2 May 11, 2010 08:19 AM
