Old Sep 09, 2012, 06:45 PM
Halfbrit42 is offline
Find More Posts by Halfbrit42
Joined Dec 2005
building boards??
what is being used for building boards...i.e. balsa wings. Stores used to carry homosote ,4x8 sheets...cant find it anymore. Need something that you can use stick pins.
Halfbrit42 is offline Find More Posts by Halfbrit42
Old Sep 09, 2012, 07:10 PM
Wylie Shaw is offline
Find More Posts by Wylie Shaw
Clearlake, CA. USA
Joined Jun 2000
Ceiling tile contact cemented to a flat surface.
Wylie Shaw is offline Find More Posts by Wylie Shaw
Old Sep 09, 2012, 07:31 PM
jetmaven is offline
Find More Posts by jetmaven
I framed up an 18" x 48" piece of 3/4 " ply on 1"x2" oak, nice and straight. When in use , i place it on an old bar stool, when not in use , it just stands up in a corner , out of the way .I also made a removeable bolt on 24" extension for the bigger sections. I cover it with a piece of ceiling tile and cut off the extra width , a couple of small dabs of construction adhesive holds it in place , just be sure to press the ceiling tile down firmly.
I have built no less than a dozen projects on the current board , no problems with pinning spars, ribs or whatever to it .
If you need to replace the surface , just pop off the used ceiling tile , remove any adhesive that has remained on the ply and start over . Cheap and easy.
jetmaven is offline Find More Posts by jetmaven
Old Sep 09, 2012, 07:41 PM
Mark Miller is online now
Find More Posts by Mark Miller
Mark Miller's Avatar
United States, WI, Waunakee
Joined Oct 2002
I get Homasote at Menards. Check out www.homasote.com for a list of suppliers. It is still the best material to build models on when using pins. Ceiling tiles are to soft to hold things form. Drywall is to hard. Cork is not bad but Homasote is cheap and has the right characteristics. I build on a piece that I have had for about 7 years. If I get a glue spot it can be sanded flat. It is just a compressed cellulose material. My father used it for exterior siding on a shed in the back yard. I painted it and some 40 years later it is still in great shape.
Mark Miller is online now Find More Posts by Mark Miller
Old Sep 09, 2012, 08:10 PM
Steve Bailey is offline
Find More Posts by Steve Bailey
Steve Bailey's Avatar
United States, IN, Mishawaka
Joined Sep 2009
I bought a 4x8 homosote sheet at Menard's about 7 months ago. They had it in the store.
Steve Bailey is offline Find More Posts by Steve Bailey
Old Sep 09, 2012, 09:32 PM
scaflock is offline
Find More Posts by scaflock
I need some building time in t
scaflock's Avatar
United States, AZ, Douglas
Joined Nov 2007
I still like my drywall for building on. I've never had any problems getting pins into it and they hold very well. If it starts getting too many pinholes in it, a little spackle, a light sanding and it's good as new. I just paint the ends to prevent moisture from seeping in to the board, but other than that I don't do anything else to it.
I've used drop ceiling tiles, homasote, sugar pine and several other types of materials to build on through the years and I always go back to the drywall. It should also be noted that I rarely if ever use CA glues and if any wood glue gets onto the drywall, it sands off without any damage to the drywall. (Try that with CA glues! )
scaflock is offline Find More Posts by scaflock
Old Sep 10, 2012, 12:30 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
A layer or two of foam core board attached to a flat surface works very nicely, but is not especially cheap.
lincoln is offline Find More Posts by lincoln
Old Sep 10, 2012, 02:11 PM
jcstalls is offline
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
I am still using 1/4" cork tiles over 3/4" MDF framed with 1"x2"s or so.
Someday I may invest in magnetic building board systems.
Jared
jcstalls is offline Find More Posts by jcstalls
Old Sep 10, 2012, 02:50 PM
Joined Dec 2005
Thanx everyone!! just changed out the stock prop on my Radian to an 11/8...that ought to kick some butt...
Old Sep 10, 2012, 03:07 PM
Norm Furutani is online now
Find More Posts by Norm Furutani
Norm Furutani's Avatar
United States, CA, Gardena
I prefer jelutong or sugar pine planks, but these are getting to be hard to find. The Great Planes board is very nice. See: http://www3.towerhobbies.com/cgi-bin...?&I=LXPF36&P=7
There is also a discussion ongoing here: http://www.rcgroups.com/forums/showthread.php?t=1582494
- Norm
Norm Furutani is online now Find More Posts by Norm Furutani
Old Sep 10, 2012, 05:46 PM
roboto65 is offline
Find More Posts by roboto65
Conroe,TX
roboto65's Avatar
USA, TX, Conroe
Joined Aug 2004
Yep have the Great planes building board has held up great.
roboto65 is offline Find More Posts by roboto65
Old Sep 10, 2012, 08:26 PM
jetmaven is offline
If you opt for the ceiling tile approach, you may want to brush on 2 coats of any left over color wall paint , flat , satin , it doesn't matter which. It firms up the surface.
Old Sep 14, 2012, 11:00 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
2X4 ceiling tile on a flat surface works for me. Finished side down.
aeajr is offline Find More Posts by aeajr
Old Sep 14, 2012, 11:54 AM
LVsoaring is online now
Find More Posts by LVsoaring
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
The paint won't soak in and warp the tile? Never heard of this idea, but I'm open minded and interested....
Ditto, that's what I use. Cheap, flat enough for my woodies, holds pins great, and just throw away and replace when they get ratty.
LVsoaring is online now Find More Posts by LVsoaring
Old Sep 16, 2012, 11:45 AM
MWCores is online now
Find More Posts by MWCores
MWCores's Avatar
Moses Lake, Wa.
Joined Apr 2008
A hollow core bedroom door works.
MWCores is online now Find More Posts by MWCores
Sold GP magnet building Board warbirdguyn951 Aircraft - General - Miscellaneous (FS/W) 3 Jun 19, 2012 12:01 AM
Wanted Building Clamps for a Magnetic Building Board stevster Aircraft - General - Miscellaneous (FS/W) 1 Jun 14, 2012 07:29 AM
Discussion How NOT to build a flying building board.... Homesick Angel Parkflyers 11 Apr 15, 2008 12:48 PM
Discussion First Build/Glass top table/Building Board/Sig Extra .46 Mist-R Mosquito The Builders Workshop 4 Sep 03, 2006 06:57 AM
