Old Sep 04, 2012, 04:17 AM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
good AV > USB(PC) adapter?
i'm going to use my laptop and APM as ground station.
the biggest problem i encounter is how to get the video signal from vRx to laptop. there are quite a lot options around.. cheap & expensive. only for FPV.. i guess 100bucks+ of hi-def solution is useless.. but looking at those products.... I got no idea how good they can be. losing signal (between vtx and laptop) will be disaster for fpv....
so i wonder if there is any people around using av> usb adapter/capture device that is reliable and relatively economical?
thanks
J
jy0933 is offline Find More Posts by jy0933
Old Sep 04, 2012, 10:14 AM
picard10th is offline
Find More Posts by picard10th
picard10th's Avatar
United States, FL, Marco Island
Joined Jan 2007
i use a easy cap but have a lot of sync problems. The frames scroll left to right, Kinda weird if I tilt camera down it usually stops so it must be some type of output changes from light levels. I tried resistors in line seems to help but not enough. Been very frustrating Just bought a Japan DVR from RMRC it was that or the AV 25 but took the buy cheap but twice advise.
1/3 ccd sony HK $16 cam
RVOSD
HP dv7 i7
picard10th is offline Find More Posts by picard10th
Sold SOLD: Hyperion usb adapter for programming titan esc & pc to eos06xx livinma1 Aircraft - Electric - Batteries & Chargers (FS/W) 4 May 30, 2011 05:23 PM
Sold hexTronik PRO 80A BESC w/ USB PC program adapter serasbach Aircraft - Electric - Power Systems (FS/W) 4 Jul 01, 2010 07:34 PM
Wanted FMA USB PC Adapter eander315 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 17, 2008 12:07 AM
WTB Realflight G2 Simulator or USB transmittor to pc adapter super_nova Aircraft - Electric - Airplanes (FS/W) 4 Sep 09, 2004 03:10 PM
PC USB Adapter for Evo Zhack Radios 4 Mar 29, 2004 12:48 PM
