Old Jul 18, 2012, 11:07 AM
ulpilotrmh is offline
Find More Posts by ulpilotrmh
ulpilotrmh
ulpilotrmh's Avatar
USA, FL, Tavares
Joined Sep 2010
Mini Topsky Wing Pin
I'm building a Mini Topsky and am questioning the placement of the wing pin. The Topsky "Plan" shows the pin inserted vertically in the wing, parrallel to the rudder, but it seems to me that it would be more comfortable if it is perpendicular to the surface of the wing. How did you guys do it? I will be using Drela's pin design.
Russ
ulpilotrmh is offline Find More Posts by ulpilotrmh
Old Jul 18, 2012, 11:42 AM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
The "pin" you are speaking of is the throwing peg? Which you want to replace with Dr. D's blade???
And then you think you want the blade installed so it doesn't stick up like normal, but laid down so it has a low long profile with the wingtip??
I don't think you will be to happy with that. The slot in the wingtip would be so long that wraping extra material around the blade would be inneffective at spreading the launch loads inboard to the wing. In other words the wing tip would be too unsuported and would fail before your tenth launch.
Install it like the instructions show.
You do have some options since you are making/ shaping your own blade.... You may opt to shape your blade so that it is a bit wider front to back , and you can also control how tall you have it out of the wingtip.
I would suggest something like 1/2 x 1-1/2 inches (finished) as a comfortable size, any more than 1/2inch is going to limit the strength of the wrap reinforcement and really weaken the wingtip.
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Jul 18, 2012, 11:46 AM
Craig Greening is offline
Find More Posts by Craig Greening
Horizon Hobby Employee
United States, IL, Mahomet
Joined Jun 2006
You can do it either way; parallel to the normal axis, or perpendicular to the wing. Most consider it personal preference, I mount mine as your instructions describe (parallel to the fin/rudder).
Craig Greening is offline Find More Posts by Craig Greening
Help! Super Mini Topsky wing failure Jwmflying14 Hand Launch 13 Nov 11, 2012 11:38 AM
Sold Topsky Mini Super, mostly built Wave Glider Aircraft - Sailplanes (FS/W) 2 Jul 11, 2012 07:36 PM
Wanted Topsky 2 Wing davidbones Aircraft - Sailplanes (FS/W) 6 Jun 29, 2012 05:48 PM
Wanted Looking for a TopSky Mini or Super Mini Garret H Aircraft - Sailplanes (FS/W) 3 Apr 11, 2012 04:12 PM
