Old Jul 07, 2012, 10:48 AM
wdwimbish is online now
Find More Posts by wdwimbish
Wayne Wimbish
wdwimbish's Avatar
United States, MO, St Peters
Joined Aug 2008
Help!
Alignment Pin Doing a Disappearing Act
Help!!!
One of my outer wing panel alignment pins on my Pike Perfect has been jammed into the tip panel. The head of the pin is now flush with the surface and there is nothing to grab onto to pull it back out.
Any ideas on how to extract it back to its proper position?
I thought I might drill a small hole in the lower skin and try and lever it back out from the inside end. Thoughts?
Thanks, Wayne
wdwimbish is online now Find More Posts by wdwimbish
Old Jul 07, 2012, 12:57 PM
SHVentus is offline
Find More Posts by SHVentus
Hawaii
Joined Feb 2009
Strong RE magnet
SHVentus is offline Find More Posts by SHVentus
Old Jul 07, 2012, 01:26 PM
R.M. Gellart is offline
Find More Posts by R.M. Gellart
R.M. Gellart's Avatar
Joined Nov 2005
Thank goodness there are two pins per side if I remember correctly. Shoot a hole for or aft of the pin (whichever applies) and insert a good piece of music wire with a bend and try to get it caught enough to start it back the other way. Perfects are tough about this.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Jul 07, 2012, 01:39 PM
jcstalls is online now
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
I did not have this challenge on my old Pike Perfect, yet, has worked on several other moldies I have had.
Dependent on the spars in the tip panel, the rear and/or front pin could be replaced with the same one.
Open your servo cover.
Push the pin all the way into the panel to dislodge it.
Work at Rocking and Rolling the panel around till the pin is near the servo hatch.
Remove with tweezers or small magnet on a stick.
If this does not work, then just got back to step two, then replace with new. SAE music wire, or if one is a "Perfect-ionist" then McMaster Carr for Metric SS rod.
Good luck and enjoy,
Jared
jcstalls is online now Find More Posts by jcstalls
Old Jul 07, 2012, 05:53 PM
AirBornOne is online now
Find More Posts by AirBornOne
I'm All Thumbs
AirBornOne's Avatar
S.F. Bay Area
Joined Aug 2002
Never payed with this airframe myself but I would try either a magnet (those real powerful kind like guys use for canopies),or a strong thread,maybe kevlar and use a Tiny drop of CA, glue the thread to the end of the pin and pull it out.
Any adhesion difficulties can be helped with baking soda.
HTH
Jay
AirBornOne is online now Find More Posts by AirBornOne
Old Jul 07, 2012, 06:49 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
If you can find a place that magnetizes and demagnetizes tools, they may have a magnet which is REALLY strong.
An alternative idea is to cut a piece of thick plywood (3/4"????) that is somewhat larger than the rib, with a generous hole where the rod is. Use some kind of glue that you can later remove, and attach the plywood over the end of the wing panel with the hold lined up with the rod. Loosely support the wing panel with a towel or your left hand (assuming you are right handed). Smack the plywood with a rubber mallet, right where the hole is. This is just an idea, so I don't guarantee the results. Particularly if you get really enthusiastic about it. You might want to start with little taps.
If this was a carbon pin you could probably drill a hole in the end, glue in a small carbon rod, and pull on that.
lincoln is offline Find More Posts by lincoln
Old Jul 07, 2012, 09:24 PM
tewatson is online now
Find More Posts by tewatson
Riddle me this...
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
Do it the easy way...get yourself a piece of pine or fir (like a 1x2 from a hardware store) about a foot long or so. A short hunk of regular 2x4 will work too, if you have that laying around. Don't use a hardwood like oak or mahogany. Lay it on a hard immobile surface like a kitchen counter and tape it on the ends so it can't move. Now, hold the tip panel vertically over it, root down, about 1-2" high and with the submerged pin about 1" away from the wood piece. You want the root surface to be more or less parallel to the wood in both axes. Drop the panel squarely onto the wood. You will need to repeat quite a few times, depending on how tight the pin is lodged. You'll get a feel for how high to hold it and such, but this really works. Done it several times.
Once you get it out, I would pull it all the way, rough it slightly, then reinsert and wick in some thin CA. Let it set several hours before reassembling.
Tom
tewatson is online now Find More Posts by tewatson
Old Jul 07, 2012, 09:41 PM
lincoln is offline
Joined Dec 2001
Still suggest you attach something to the root so if your hit is not perfectly square, you don't break it. But perhaps you are a bit more accurate than I am!
Old Jul 07, 2012, 10:16 PM
Riddle me this...
tewatson's Avatar
Joined Oct 2006
That's why a soft wood like pine, and limiting the drop to an inch or two. Still, taping a thin piece of wood to the root as well is probably a good idea too.
Tom
Old Jul 08, 2012, 03:00 AM
jtlsf5 is online now
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Had the same problem with a Supra. Drilled a smallish hole (3/16") in the tip panel root about 3/8" from the pin, then took a piece of 1/8" music wire and bent an "L" into the end, about 1/2" long. Cut the music wire about 6" long, then put another "L bend into the open end to have something to grab. Now insert the smaller arm into the inside of the wing via the hole, and use the music wire tool to tap on the pin from the inside until it has retreated outside enough to get a hold of with a pair of pliers. Pull it out to its desired spot, then use thin CA to secure it. Go back to the hole in the wing center and gently chamfer it. I use an old case reamer from my reloading days.
JT
jtlsf5 is online now Find More Posts by jtlsf5
Old Jul 08, 2012, 08:12 AM
Mark Miller is offline
Find More Posts by Mark Miller
Mark Miller's Avatar
United States, WI, Waunakee
Joined Oct 2002
Wayne,
If the pin is the rear one push it all the way in and then retrieve it through the servo hole. Put is bad in with a dab of epoxy to hopefully keep it from moving in again.
If the pin is in the front the drill a hole just inside of the location and push it all the way in and retrieve throughout he hole. I have tried to push it our and the hole needed is really pretty large compared to the one to get it out.
Mark
Mark Miller is offline Find More Posts by Mark Miller
Old Jul 08, 2012, 08:31 PM
Wayne Wimbish
wdwimbish's Avatar
Joined Aug 2008
Hey Guys,
Thanks for all the advice and hints. Yes it is the front pin and it is in pretty tight.
a) I don't thinking tapping would dislodge it compared to the ill effects of the jarring on everything else.
b) Too tight also for magnets.
c) I would be concerned with gluing it in place if trying to glue a string on it to pull it out.
d) Considered making a hole in the shear web in the servo pocket to retrieve through but think that would introduce a stress riser. (Do you think that would be a problem it the hole was round???)
So far the ideas that seem to be the best are the ones of making a hole in the root rib to either pull through with a wire or to retrieve through depending on the size of the hole.
I think I will go that route and start with a small hole and a wire to push it out from the inside. If I can't get that to work then I will just enlarge the hole followed by pushing in and retrieving through the hole.
Thanks again for all the help,
Wayne
Old Jul 09, 2012, 04:29 AM
I'm All Thumbs
AirBornOne's Avatar
S.F. Bay Area
Joined Aug 2002
I don't believe making a hole in the shear web can do anything but harm.
Get help but do not put a hole in the shear web.
J
Old Jul 11, 2012, 12:02 AM
Riddle me this...
tewatson's Avatar
Joined Oct 2006
The tapping method really works, even for tightly fitted pins. You're not going to break a Perfect tip root if done correctly.
Tom
Old Jul 11, 2012, 08:43 PM
Paulbilbo91z9f is offline
Find More Posts by Paulbilbo91z9f
Fly It Like You Stole It !!
Paulbilbo91z9f's Avatar
United States, MA, Pittsfield
Joined Sep 2011
This may sound foolish, but why retrieve the pin at all?
I would push the pin into the wing and then stand the wing-tip on end. Using one of the flexible CA glue snouts, reach in and glue the derelict pin in place against the root rib, out of the way. Then just insert a new pin and thin CA it where it belongs.
Don't try to get the pin out of the wing-tip. If it won't come out the servo cover, leave it in there.
Murph
Paulbilbo91z9f is offline Find More Posts by Paulbilbo91z9f
Question bt mod for mwc what pins do i solder it to ? crash8384 Multirotor Talk 16 Jun 11, 2012 02:43 PM
Help! Clearview SE Stock Airplane Disappeared Cory Simulators 7 May 03, 2012 10:46 PM
Discussion rc boat disappeared mysteriously in the lake (3':31") take a look at footage megacorp Racing Boats - Electric 9 Mar 25, 2012 05:03 PM
Discussion Micro 9 act chip pins? customminatures Scratchbuilt Indoor and Micro Models 8 Sep 20, 2007 07:51 PM
Do threads disappear a lot around here? watersharer Site Chat 2 Aug 03, 2001 04:11 AM
