Old May 16, 2012, 06:09 PM
Sofaman NJ is offline
Find More Posts by Sofaman NJ
The 1st Sofaman
Sofaman NJ's Avatar
United States, NJ, Hawthorne
Joined Mar 2012
Idea
Aerobalsa Blade Covering
Hey guys! Did some R&D today with Aerobalsa blades. I think you will enjoy the video and the "new" technique that I have used.
Check it out!!! Mike Smith......36" blades are back!!!! You will like this!!!
New Autogyro Rotor Covering (8 min 18 sec)
Sofaman NJ is offline Find More Posts by Sofaman NJ
Old May 16, 2012, 08:01 PM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
Looks like it flew nice, is that the stock landing gear for that model? Those give it a great appearance.
Nice work/ flying- makes me want to get one back out!!
doug
dougmontgomery is offline Find More Posts by dougmontgomery
Old May 16, 2012, 08:08 PM
The 1st Sofaman
Sofaman NJ's Avatar
Joined Mar 2012
Hey Doug,
The landing gear is as per the plans minus the bends from years of abuse. Hahaha! It does fly well and I thank you for the kind words.
Dave
Old May 16, 2012, 10:31 PM
jodini is offline
Find More Posts by jodini
AND FOR MY NEXT TRICK....!
jodini's Avatar
Omaha Millard, Nebraska, United States
Joined Sep 2004
Very nice Dave! I love that covering! It reminds me of "old school" covering with the fiber!
So spill the beans....can you give me a link to the actual product?
Nice flight man!
Joe
jodini is offline Find More Posts by jodini
Old May 17, 2012, 05:36 AM
The 1st Sofaman
Sofaman NJ's Avatar
Joined Mar 2012
Hey Joe,
The tape is unlike any other I have used in the past. Adhesion is crazy strong! Makes the blades strong yet flexible. The weight of the tape vs. Monocoat gives the duct tape the edge in heaviness. The extra weight allows the blades to flap better than the lighter Monocoat. No need to add top weights anymore with the AB blades.
http://www.amazon.com/Scotch-Transpa.../dp/B0000DH8I8
I realize that the "purists" cringe when they see me trying something different. But, I had wanted to try this since finding this tape in Sears Hardware Store. I was thinking it would work just fine.
From the trailing edge, I line up the tape's edge and adhere the full length and leave a couple inches extra on each end. Do the trailing edge on opposite side and seal the ends nice and tight. Then for the leading edge, overlap the existing tape on one side by 3/8 of an inch. Wrap around the leading edge and adhere so it overlaps the opposite side. Cut your sealed ends close to the shape of the ends and you are pretty much done.
I drill my holes past the CG of blade towards the leading edge. Basically beside the hardwood, into the balsa. This allows the ass end of the blade to raise up a bit during spin up and gives it a higher rpm.
Lastly....it cost very little for all 3 blades and they work!!!! Can't argue with success.
Dave
Old May 17, 2012, 07:39 AM
jodini is offline
jodini's Avatar
Joined Sep 2004
I'm off to home depot!
Old May 17, 2012, 08:01 AM
The 1st Sofaman
Sofaman NJ's Avatar
Joined Mar 2012
Off to fly again...........
Still need to make a new tailplane.....
After flying.....
Happy rotations guys!!!!
Sofaman....
Old May 17, 2012, 10:01 AM
SafeLandings is online now
Find More Posts by SafeLandings
It was a GLITCH! Honestly!
SafeLandings's Avatar
Stourport on Severn ,Worcestershire, United Kingdom
Joined Dec 2007
That's a floater Dave, they seem to work well with the new found covering material. Easier and cheaper and works well
Regards
Rich
SafeLandings is online now Find More Posts by SafeLandings
Old May 17, 2012, 11:03 AM
The 1st Sofaman
Sofaman NJ's Avatar
Joined Mar 2012
Thanks Rich for the support. Yes she is a floater for sure. I did another experiment with the blades and they paint well if needed. I just came back from flying....no mishaps.....just the ugly tail plane!!!!
Sofaman
Old May 17, 2012, 11:32 AM
gearwolf is offline
Find More Posts by gearwolf
Joined Apr 2012
Why did you overlap the pieces? Wouldn't that change the airfoil shape? Btw excellent idea using duct tape. I've been having a hard time finding a way to cover the blades using materials from places like Home Depot and Sears.
gearwolf is offline Find More Posts by gearwolf
Old May 17, 2012, 11:52 AM
The 1st Sofaman
Sofaman NJ's Avatar
Joined Mar 2012
I overlap the piece that goes over the leading edge as it seals the other two pieces. I gambled that the rotors being slow moving air foils that they may work as a K-F type airfoil......full size planes dont use this as the lift to weight ratio is poor....but RC planes use it and seem to have better control with the airfoil. I am not and aeronautical engineer, but I know guys who fly gliders and they use it.
http://en.wikipedia.org/wiki/Kline%E...gleman_airfoil
I find the blades have lots of lift....spin up like crazy and are tough. Do they really work as KF??? No idea....and honestly really dont care nor would I want to debate about this subject. As long as it works, that is my concern.
Non technically speaking.....they work extremely well and fly the heavy bird very light. I'm happy with it.
Sofaman
Old May 17, 2012, 09:18 PM
nja is offline
nja
Find More Posts by nja
nja
Vero Beach, Florida USA
Joined Aug 2010
Hi Dave,
Nice work. Can you post the weight for your blades?
Nils
nja is offline Find More Posts by nja
Old May 17, 2012, 09:34 PM
Glendale,Az.
Covering
So would this be an option for tape covering?
This is how I would do monokote covering without the top seam.
Doug
Old May 17, 2012, 09:49 PM
The 1st Sofaman
Sofaman NJ's Avatar
Joined Mar 2012
The tape is not wide enough. That would be nice, the way you drew it. But it does not matter.......the way I did it works. I tried the old school fiber tape like for the Zaggie wings and for combat foam planes and that just did not adhere as well as the Scotch TOUGH Duct Tape.
Old May 17, 2012, 09:59 PM
The 1st Sofaman
Sofaman NJ's Avatar
Joined Mar 2012
Originally Posted by nja View Post
Hi Dave,
Nils
Nils,
Sorry I missed your post. I will have to weigh one tomorrow afternoon and post it.
Dave
Discussion Aerobalsa rotor blades question bzfrank Auto Gyros 0 Apr 15, 2012 04:41 PM
For Sale neoprene canopy and blade covers socalheliparts Aircraft - Electric - Helis (FS/W) 1 Mar 28, 2012 10:16 AM
Discussion Aerobalsa blade finish JochenK Auto Gyros 6 May 30, 2007 03:13 PM
Discussion Swift - Gluing the blade root cover philiusm Electric Heli Talk 2 Mar 11, 2007 04:13 PM
G3p0-Aerobalsa rotor blade help-Mickey dougmontgomery Auto Gyros 4 Nov 09, 2005 10:24 AM
