Old Mar 16, 2011, 05:09 PM
talonxracer is offline
Find More Posts by talonxracer
talonxracer's Avatar
fishs eddy n.y.
Joined Apr 2003
LAK-17FES, Interesting!
Now for those who do not have ready access to a tug or a slope and want a scale plane with the ease of electric power, here is the typical R/C solution applied to a full scale bird, the LAK-17FES http://www.lak-aviation.de/lak/fes.php I am sure you would still need either a dolly or bungee catapult to get clearance for the prop.
talonxracer is offline Find More Posts by talonxracer
Old Mar 16, 2011, 05:59 PM
Sutton Bank is offline
Find More Posts by Sutton Bank
North Yorkshire UK, on a big hill facing the prevailing wind. Coincidence?
Joined Oct 2007
I just love it. At last we can cut the nose of our beautiful models and it's actually scale! And no need to bother with expensive, heavy, troublesome, high thrust line, CG-shifting SLS's.
For fun, I just worked out it flies at 17 watts/pound! I suppose the sailplane is just so clean and efficient it only needs that tiny input to offset frictional losses.
Anybody make a scale model of this?
Rog
Sutton Bank is offline Find More Posts by Sutton Bank
Old Mar 16, 2011, 07:51 PM
fishs eddy n.y.
Joined Apr 2003
I brought it up specifically for those scale die-hards who couldnt/wouldnt/shouldnt break the scale requirement but always wanted to try electrics. Here is your opportunity!
Old Mar 16, 2011, 08:04 PM
s2000 is online now
Find More Posts by s2000
so. cal.
Joined Jan 2006
OK, soon as someone makes a decent 1/3 scale version, I am in. Cool!
s2000 is online now Find More Posts by s2000
Old Mar 17, 2011, 02:26 AM
mikegbogh is offline
Find More Posts by mikegbogh
Upwardly Mobile
mikegbogh's Avatar
Roodepoort, South Africa
Joined Aug 2007
Hhhmmmm,
I have a big LAK model and all the electrics, all I need is some white paint for the spinner and prop.........now you got me thinking again
PS what size Lipo's in the full size and do they charge off their car battery?
mikegbogh is offline Find More Posts by mikegbogh
Old Mar 17, 2011, 04:08 AM
Joined Oct 2007
Hey Mike,
They use Li-Ion rather than LiPo. 85Volts is about 26S LiIon. That'll need a big charger - probably mains.
Rog
Old Mar 17, 2011, 10:14 AM
fishs eddy n.y.
Joined Apr 2003
The LAK site states the batteries are recharged in 4 hours, and at 85volts I would expect the charger is at least 110vac. I wonder if a few solar panels on the rear deck would allow any inflight recharging?
I seen a few pictures that show the prop is sorta inset into the spinner slightly when closed, very clean setup.
Old Mar 17, 2011, 10:59 AM
xroadie is offline
Find More Posts by xroadie
Xroadie
xroadie's Avatar
St. Louis, Missouri
Joined Mar 2006
Wow that is awesome! Finally an electric model that perfectly emulates an original aircraft. Looking at the photos I can't figure out how they get any ground clearance for the prop!?!
Maybe they use a big dolly like we do, or the landing gear is adjustable, like a low rider LOL
xroadie is offline Find More Posts by xroadie
Old Mar 17, 2011, 11:13 AM
s2000 is online now
so. cal.
Joined Jan 2006
Since they call it a sustainer, I take that as meaning they get towed in the traditional way, (tow hook located on retract) and then once in the air the nose prop has enough power for sustained flight. Might be fun to try disconnecting the towline by blipping the prop though!
Old Mar 17, 2011, 12:13 PM
fishs eddy n.y.
Joined Apr 2003
I would expect the normal mode of launch is by winch(or tow) and being a sustainer the range and climb rate would be rather limited, but more than enough to do the job seeing all the negatives of present sustainers are eliminated. This system only added 77lbs, well below the weight of other sustainers. A larger capacity battery and larger motor up front would be interesting as well with 18m wings.
The video on the LAK site shows the controller interface showing 20 amps running it in a garage, I thought it was bad enough with the wind storm of my small NEU motors i could just imagine the wind storm from this setup in a garage!
It could get costly if ya blip too many tow ropes, but with my luck the prop would not cut the line but just act as a winch and reel in the tow plane!
Old Mar 17, 2011, 12:15 PM
xroadie is offline
Xroadie
xroadie's Avatar
St. Louis, Missouri
Joined Mar 2006
OK...that makes sense! I guess if we wanted to try it on a scale model, we would have to have the tow release on the retract like the original! But don't try blipping the prop if they are using 600lb test spectra!!
Old Mar 17, 2011, 12:46 PM
scottrod31 is offline
Find More Posts by scottrod31
have gun will travel
scottrod31's Avatar
USA, MI, Ann Arbor
Joined Apr 2010
Looks like a tow release hole in the spinner
scott
scottrod31 is offline Find More Posts by scottrod31
Old Mar 17, 2011, 12:59 PM
xroadie is offline
Xroadie
xroadie's Avatar
St. Louis, Missouri
Joined Mar 2006
scott
No...that is for the 20mm cannon
Old Mar 17, 2011, 02:17 PM
fishs eddy n.y.
Joined Apr 2003
scott
That would be a cooling air inlet, just like a RFM F5B spinner
Old Mar 17, 2011, 02:53 PM
scottrod31's Avatar
USA, MI, Ann Arbor
Joined Apr 2010
I like the 20mm cannon idea better
scott
Discussion Scratch built LAK mikegbogh Scale Sailplanes 43 Sep 28, 2009 06:14 AM
Video LAK 19 Maiden flight mikegbogh Sailplane Talk 11 May 01, 2009 03:41 PM
Gallery show us ur real or rc interesting boats realy interesting b36roxs Dock Talk 14 Mar 06, 2007 04:01 PM
Discussion Interesting. More interesting if people can critique.. lrsudog Life, The Universe, and Politics 19 Nov 13, 2006 07:24 AM
Interesting site featuring interesting (and exciting!) batteries and cells! Hogster Batteries and Chargers 4 Dec 01, 2004 07:21 AM
