Old Apr 12, 2010, 04:20 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Data spikes ICE 75 ESC
I am loving the data logging but sometimes get wild spikes on the data - any ideas?
I know I am not drawing 244 amps.
And any way to edit them out of the file?
Old Apr 12, 2010, 04:34 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
The data logger just uses a standard Microsoft spreadsheet format so you can easily edit it is you have the program (Excel or equivalent).
You can also use your mouse to make a box and the graphics software will zoom in and just plot what’s in the box. That’s very useful for taking a closer look at parts of the graph.
RC Man is offline Find More Posts by RC Man
Old Apr 12, 2010, 10:05 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
Tried that but every time I edit it - the graphical viewer errors and says invalid file type. I save it as comma separated values file. ??
But the zoom may be all I need - since it re-calcs the highlighted section. Thanks man!
Old Apr 13, 2010, 09:55 AM
Bernie Wolfard is offline
Find More Posts by Bernie Wolfard
Castle's Chaos Corner
Bernie Wolfard's Avatar
Olathe, KS (next to the Castle)
Joined Jun 2001
PDA4you,
This is a bug in the data logger. Your graph shows three flights. The logger changes the scale on the flights subsequent to the first. This will be fixed in the next update. Without the big spikes the data will be easier to see with multiple logging sessions as the scale will not change. For the time being ignore the spikes and use the zoom feature as RC Man said.
Bernie
Bernie Wolfard is offline Find More Posts by Bernie Wolfard
Old Apr 13, 2010, 12:47 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
Thanks Bernie - will do.....the zoom is nice BTW.
Old Apr 16, 2010, 06:35 PM
MichaelT1960 is offline
Find More Posts by MichaelT1960
Mooresville, NC
Joined Dec 2004
Temperature spike...
Bernie,
I was out flying today with my new Castle ICE Lite 75 and ICE Lite 50 and love them in governor mode! The autorotation setting works great...first time I tried an auto using an electric heli (Trex 500)!
I too noticed a temp spike in the middle of the first session on my ICE50 in a Trex 450 Pro. I don't think that the temperature could have jumped that fast? Is this a bug also?
Thank you,
Michael
MichaelT1960 is offline Find More Posts by MichaelT1960
Old Apr 17, 2010, 01:45 AM
MrE is offline
MrE
Find More Posts by MrE
MrE
United States, WA, Gig Harbor
Joined Aug 2007
Interesting. I wonder whats causing those spikes?
I have 5 different ICE and HV ICE controllers all running the latest software and Im not getting any spikes at all.
MrE is offline Find More Posts by MrE
Old May 01, 2010, 04:01 PM
BobRCnut is offline
Find More Posts by BobRCnut
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
Bernie, I'm seeing these spikes as well, using an ICE75, but mine are in the current and watts graphs. I found a post by Patrick in another thread that implied that, at low currents, the logging resolution may be causing it. Since my session was the very first spoolup on a new heli, I never got up to liftoff RPM (max recorded headspeed was 1200), and the max. current recorded was about 7 amps. Do you concur with Patrick's comment, or is this still part of the bug you referred to in Post #4 here? I'm using the latest ESC firmware and the latest graph viewer. My spikes show up in both amps and watts, but there is no voltage fluctuation and no recordable ripple, just a 1-2 amp change in current. This was a single logging session with the log data cleared beforehand, so I don't think the graph scale would have changed.
BobRCnut is offline Find More Posts by BobRCnut
Old May 03, 2010, 09:02 AM
BobRCnut is offline
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
Followup to my previous post #8: It definitely looks like a resolution or granularity situation. I checked the log file contents with Excel, and all the numeric values for current are in steps, or multiples, of 0.9 amps, and at some points you can see the current value "oscillate" up and down by 0.9. The next run should tell; I'm taking small steps because both the heli and the radio (Aurora 9) are new.
Old May 06, 2010, 07:18 AM
FlyingW is offline
Find More Posts by FlyingW
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
You can edit out the bad data in the files using text editor instead of Excel.
FlyingW is offline Find More Posts by FlyingW
Old May 06, 2010, 04:39 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
Zoom is working great for me as the user pointed out to me in the post above.
Old May 07, 2010, 01:23 PM
BobRCnut is offline
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
At this point I think the current spikes are insignificant, although it does prevent using the data log to determine receiver/servo current loads.
Rant Bug hunt; (data spikes, spurious data, seagull 2.4ghz screen very slow GPS updates ) equusine Eagle Tree Systems 34 Apr 21, 2010 02:34 AM
Sold Brand New Castle Creations ICE 75 ESC viperjody Aircraft - Electric - Power Systems (FS/W) 1 Apr 14, 2010 12:20 AM
Discussion Need some advice on data logging CC-Ice 75 esc please. JEFFRO503 Power Systems 4 Mar 17, 2010 07:18 PM
For Sale Castle creations phoenix ice 75 esc with usb linkphonix 75 esc brand new stevfly Aircraft - General - Miscellaneous (FS/W) 0 Feb 28, 2010 06:24 PM
Help! Bug hunt; (data spikes and spurious data) equusine Eagle Tree Systems 0 Jun 18, 2009 04:32 AM
