Old Mar 03, 2013, 02:39 PM
Froglube's Avatar
United Kingdom, England, Lancs
Joined Jul 2012
Making a winder
Hi all
Not had any chance any modelling in the last few weeks and the project to make myself a stooge is on hold until I get the heavy camera tripod back off the eldest who has mounted some big binocs on it for star gazing. However today I picked up a Leytool hand drill for a quid at a carboot
It took a couple of hours to de rust and clean all the glue and paint splashes off but the mechanism works well and it should make a good basis for a winder for the boys planes. It will keep them off my beloved KP winder anyway.
I appreciate that the chuck on its own wont be secure enough to hold the crochet hook in place. I don't have welding gear so am thinking of pinning the hook in the central hole in the spindle and using the outside of the chuck to stop the pins coming out.
ATB
Tom
Froglube is offline Find More Posts by Froglube
Old Mar 03, 2013, 05:13 PM
Ancaster, Ontario, Canada
Joined Oct 2005
That looks very sturdy Tom. Nice find. You might want to make a "counter" for your unit.
Also consider making a "blast tube" for winding the rubber so you don't damage your model if the ruber breaks.
John
JohnAV8R is offline Find More Posts by JohnAV8R
Old Mar 04, 2013, 01:25 AM
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
How about using a counter from a jump rope, like below...?....they come extremely cheap, and I assume they are non-friction easy spinning....
Gluehand is offline Find More Posts by Gluehand
Old Mar 04, 2013, 02:18 PM
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
I was browsing the Hobby King site and found this:
http://www.hobbyking.com/hobbyking/s...es_Models.html
Trisquire is offline Find More Posts by Trisquire
Old Mar 04, 2013, 04:13 PM
Gold Coast Australia.
Joined Jan 2005
That Leytool hand drill makes a VERY good winder for rubber jobs.
I have two of them and have used them for many years winding large.....16 strands of quarter rubber, down to small stuff.
I have extended the handle and have taken off the chuck, drilled a 1/8th hole through the threaded part and put a 1/8th piano wire hook into it for safety rather than a hook coming out of the chuck.
A good idea is to pull it apart and grease it inside as well.
gossie is offline Find More Posts by gossie
Old Mar 04, 2013, 04:45 PM
Froglube's Avatar
Joined Jul 2012
Cheers for those thoughts folks.
We got one of those cheep I electric winders and on a couple of rechargeable batteries it works surprisingly well, on the sub 24 inchers we fly in the park we can get 250 to 300 turns on for trimming flights quite quickly. Another favourite is a bent nail though a cork with a slot the size and shape of the props hub, held in the chuck of my beloved Makita 18 watt drill. It's like super fast finger winding. For the lads Cloud Tramps I finger wind the first one, memorise the number and thickness of the knots at the required number of turns then for the rest of the flights I just wedge the cork on the prop, squeeze the trigger and switch off when the knots look right. Fitting a counter would be better of course
What sort of grease should I be using? All I have in is graphite grease in some SLR cleaning kits!
OK here's were I show my ignorance, how exactly do you use a blast tube? Stretch winding does scare me!
ATB
Tom
Old Mar 04, 2013, 04:56 PM
Gluehand's Avatar
Joined Sep 2008
I think, with plastic gears, you'd better play on the safe side, as several (particularily petroleum based) greases don't do the plastic any good in the long run....
I would try something as simple as ordinary soap, or similar...
My 2 C's....
Old Mar 04, 2013, 05:09 PM
Joined Jan 2005
Just found a pic of one of my winders.
Blast tube I always use but hard to describe......I'll have a go if no one else comes in.
Should think any old grease would do, as the Leytool has metal gears..........I have a tub of motor grease here and another tub of marine grease.
Cool Winder antenna tracker typicalaimster Video Piloting (FPV/RPV) 10 Feb 07, 2013 09:46 PM
Sold F3J Winders and Pulleys SmokinJoe101 Aircraft - Sailplanes (FS/W) 7 Jan 29, 2013 04:06 PM
Sold Winder DLG Kit by Jeff Winder ## sold ## FredM Aircraft - Sailplanes (FS/W) 2 Mar 22, 2010 01:14 PM
Winder turn counter - interested? Dave Lofthouse Free Flight 31 Jul 30, 2004 02:08 PM
Yippee! Easy Peasy hand actuator winder gbarc Indoor and Micro Models 3 Apr 02, 2004 02:56 PM
