Old Jun 28, 2007, 12:37 PM
boatman1938 is offline
Find More Posts by boatman1938
Joined Jul 2006
Prop rotation question
I have a 6 volt car fan motor with a 1/4" shaft and 3" diameter motor, that goes clockwise when looking at the shaft. Do I need a right hand prop or a left hand prop? I'am building a 8" wide by 24" long boat. Thanks Dan
boatman1938 is offline Find More Posts by boatman1938
Old Jun 28, 2007, 05:15 PM
Gravman is online now
Find More Posts by Gravman
United States, TX, La Porte
Joined Apr 2007
Right hand
Gravman is online now Find More Posts by Gravman
Old Jun 28, 2007, 05:27 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
No problem either way... just reverse the polarity to the leads, it'll go the other way.
But, umm, sure you want to use that beast of a motor? A MUCH smaller motor should do the job in that sized boat.
Pat M
patmat2350 is offline Find More Posts by patmat2350
Old Jun 28, 2007, 05:53 PM
bigford is offline
Find More Posts by bigford
master boat slacker
USA, NY, Mastic Beach
Joined Feb 2006
when is a motor that size really needed? in a
amsterdam or smit nederland? or bigger tug?? just wondering
bigford is offline Find More Posts by bigford
Old Jun 28, 2007, 06:02 PM
Metatron is offline
Find More Posts by Metatron
Respect & Honor
Metatron's Avatar
Portugal
Joined Nov 2006
The amsterdam uses two class 500 motors, like the rotterdam, with more then enough power.
What is the boat your using this motor on ?
Metatron is offline Find More Posts by Metatron
Old Jun 28, 2007, 08:27 PM
Joined Jul 2006
patmat2350
How do I reverse the polarity to the leads?
Old Jun 28, 2007, 09:02 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Dan- tell us about your boat, we can make a much better recommendation on the motor and prop. Speedboat? Tugboat? Bait dropper?
Old Jun 28, 2007, 09:49 PM
Joined Jul 2006
Thinking of building a Chris craft style boat 24"x8"
Prop size?
Motor 6 volt car fan motorcost $5.00
Battery 6 volt 10 amp cost $16.00
Boat will be a foam core mold with 1/8" wood glued to the foam mold then covered with mahogany veneer and 2 oz fiberglass cloth.
All this is in the planning stages. Trying to stay on the cheap side.
I have a Futaba 2PL AM radio and a Hitec 1/4 servo for the rudder.
Old Jun 28, 2007, 10:48 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
Most of the Dumas Chris Crafts are about 30" long and 7-9" wide. The recommended motor is a 540 size, about 1.5" diameter with a 1/8" shaft. Prop size is about 1.5" . A 6 cell 7.2V NiCd or NiMh battery works well in the boats. The DUmas kits are built plank on frame (or bulkhead) and mostly double planked. First layer is 1/16" ply laid on the diagonal or some expanded PVC foam (Sintra).
The Hitec 1/4 servo is overkill for the rudder, a standard servo is sufficient.
Connect the battery leads to the motor, if the motor is spinning the wrong direction, reconnect the battery leads to the other motor leads.
CG Bob is offline Find More Posts by CG Bob
Another dumb question about prop rotation. bc-slowflyer Flying Wings 4 Apr 12, 2005 07:56 PM
tigermoth prop newbie question ping1 Parkflyers 1 Mar 04, 2002 07:08 AM
Pusher prop and rotation ????? ivorz Electric Plane Talk 1 Feb 16, 2002 07:43 PM
Zagi 400X - Prop Change Question sbuechler66 Foamies (Kits) 9 Sep 07, 2001 08:27 PM
Graupner Prop assembly question cold boy Beginner Training Area (Aircraft-Electric) 3 Jul 11, 2001 12:53 AM
