Old Dec 28, 2005, 09:51 PM
schrederman is online now
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Question
Timers
I haven't built a Nordic in many years, but now find I have 3 to build. I need at least 1 DT Timer. Any suggestions? I looked at the sources on this site and found not one... I really don't want to spend an arm and a leg for a vintage towliner... Any help out there?
Jack Womack
Houston TX Area (for now)
schrederman is online now Find More Posts by schrederman
Old Dec 28, 2005, 10:59 PM
gossie is online now
Find More Posts by gossie
Gold Coast Australia.
Joined Jan 2005
You could try Texas Timers---they are in your area. On holiday at the moment though.
l pulled it up by doing a "Google" texas timers That was enough to get it.
They have single function, plus others. $38.00 l think it said.
eBay is another clue-----type in KSB timer-----they often come up on the "Bay.
gossie is online now Find More Posts by gossie
Old Dec 29, 2005, 02:33 AM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Do they still make the Tomy Toy walking toys? If you don't mind some playing you can make some nice little timers with these mechanisms.
I've also got a bunch of the old Tatone and KSB timers. Let me check it out but if, like I suspect, I've got more than I need I could be persuaded to part with one if it's going to an appreciative home like in a nordic.
BMatthews is online now Find More Posts by BMatthews
Old Dec 29, 2005, 09:05 AM
dephela is online now
Find More Posts by dephela
the flying is good
dephela's Avatar
USA, CT, Hamden
Joined Oct 2002
Also:
http://www.faimodelsupply.com/
their catalog has many more timers than the online site.
dephela is online now Find More Posts by dephela
Old Dec 30, 2005, 11:17 AM
PietenpolAC is offline
Find More Posts by PietenpolAC
PietenpolAC's Avatar
Budapest, Hungary
Joined Mar 2005
I guess it depends on what you want to do with the model. I just want to be able to get mine back without it going OOS. Not used for contests. I made a little timer out of two pieces of aluminum tubing and silly putty. I "calibrate" it at the field each time by timing how long it takes to release with various wraps around the axle. If the temperature doesn't change significantly over the course of the flying period, it is gives pretty dependable times. Simply to make, light, extremely cheap, reliable and almost all of it fits into the fuselage out of sight.
Bruce
PietenpolAC is offline Find More Posts by PietenpolAC
Old Jan 02, 2006, 10:12 AM
Mange-33989 is offline
Find More Posts by Mange-33989
Joined Jan 2006
I would suggest taking a look at Mikes site he sells a number of timers that could be used in a "vintage" model.
http://www.freeflightsupplies.co.uk/
Magnus Söderling
Mange-33989 is offline Find More Posts by Mange-33989
