Old May 19, 2015, 03:57 PM
KRProton is offline
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Question
Convert two 2S packs to one 4S pack (?)
Hi guys.
I have two 2S LiPo packs I would like to convert to a 4S pack in series. I know how to join the discharge leads to do this (connect a positive and a negative lead from each pack to each other and connect the remaining + & - leads to a discharge connector - say Deans or what have you).
But what I want to do is "permanently" series these packs by soldering two of the discharge leads together and mating all the balance wires together into a single 4S balance connector so I can charge (and balance) the pack as one 4S pack.
So, what do I do with the balance wires? I think the answer is to "Y" the two negative (black) balance wires together and connect into the negative port in a 4S balance plug (that has five receptacles for five wires). Then, connect the remaining four wires into the other four ports of the balance plug.
Other than the negative wire that goes on the end, does the order of the rest of the wires matter?
Will I then be able to charge (and balance) the battery as a 4S pack?
Thanks.
Tim
KRProton is offline Find More Posts by KRProton
Old May 19, 2015, 04:38 PM
KRProton is offline
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Never mind for now, but go ahead and chime in with comments/suggestions if you have any.
I found this after doing a google search;
I'll show you my work after it's done.
Tim
Old May 20, 2015, 02:39 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Yes, what you've found with Google is correct. The heavy link that goes between cell 2 and cell 3 in your diagram will in your case be the black lead from one pack (cells 1 and 2) soldered to the red lead of the other pack (cells 3 and 4).
You can dispense with either the black balance wire from one pack or the blue balance wire from the other, so that you end up with only five balance wires instead of six. But you've got to be careful that you pick the right ones -- the one you get rid of must be one of the two that connects to the cell 2/cell 3 junction.
Edit: Here's my edit of your diagram to better explain what I've said, using the actual colours of your wires
abenn is offline Find More Posts by abenn
Old Yesterday, 10:10 PM
KRProton is offline
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Thanks for your comments abenn.
I got my new 4S battery pack made up yesterday. I know it's a basic concept and process, but I've never "built" a pack before. After getting all the wires soldered I connected my LiPo checker and what do you know, nothing went up in smoke and all the cells were "on-line." Then I applied some kapton tape and heat shrink (but forgot to take pics of the finished product).
Well, now I'm off and running!
Tim
Old Yesterday, 11:21 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Nice work, KRP!
mw
Mark Wood is offline Find More Posts by Mark Wood
Sold For Sale New & Like New Thunder Power 65C 7700mAh Lipos: Two 2s & Two 3s; One 2s 6600 jgalexander Aircraft - Electric - Batteries & Chargers (FS/W) 7 Jan 20, 2014 09:06 PM
Sold New & Like New Thunder Power 65C 7700mAh Lipos: Two 2s & Two 3s; One 2s 6600mAh jgalexander Aircraft - Electric - Batteries & Chargers (FS/W) 2 Dec 19, 2013 08:00 PM
Sold Thunder Power 65C 7700mAh Lipos: Two 2s & Two 3s; One 2s 6600mAh jgalexander Aircraft - Electric - Batteries & Chargers (FS/W) 2 Dec 07, 2013 12:33 PM
Discussion How to make a 4s pack out of two 2s packs swatman260 Batteries and Chargers 3 Jun 12, 2009 01:51 PM
Discussion Turning two 2s packs into one 4s pack, balanceable? Nick Cappa Batteries and Chargers 7 May 03, 2009 12:55 PM
